Chart Marking Overlapped
Cliven
Post by Cliven » Fri Oct 28, 2005 3:03 am
hi there,
I am using Teechart Pro ActiveX Control v5 on vb6,
what happen is that, when I tried to draw a pie chart,
and set the chart marking visible to true,
the chart marking overlapped due to the small slices of
series items.
Further more, is there a way to set the decimal point appear in the
legend?
Is there a way to work around?
Ken
Pep
Post by Pep » Wed Nov 02, 2005 8:27 am
Hi Ken,
to solve the marks overlapping you could customize the Marks position, using similar code to the following, it also shows how to format the Values which will appear in the Marks and Legend :
With TChart1
    .Aspect.View3D = False
    .AddSeries scPie
    For i = 0 To 5
        .Series(0).AddXY i, Rnd * 1000, "", clTeeColor
    Next i
    .Axis.Left.Minimum = 0
    .Environment.InternalRepaint
        With .Series(0).Marks.Positions.Position(i)
            .Custom = True
            .LeftTop.X = .LeftTop.X + 40
            .LeftTop.Y = .LeftTop.Y + 70
        End With
    Next i
    .Series(0).Marks.Arrow.Visible = False
    .Series(0).ValueFormat = "##.##"
End With
