Multi-line node text not correctly displayed
Collinor
Post by Collinor » Mon Jul 14, 2014 11:19 am
In the TTree component of TeeChart 2014 of May 12, 2014, multi-line node text not correctly displayed, if the line count is even.
Therefore line 4164 in TeeTree.pas, function TTreeNodeShape.DrawText
vtaCenter: tmpPosY:=tmpMidY + Round( (t*tmpH) - ((tmpCount div 2)*tmpH) - (tmpH*0.5) );
has to be fixed as follows:
vtaCenter: tmpPosY:=tmpMidY + Round( (t*tmpH) - ((tmpCount div 2)*tmpH) - (tmpCount mod 2)*(tmpH*0.5) );
Re: Multi-line node text not correctly displayed
Post by Yeray » Tue Jul 15, 2014 2:17 pm
I can't reproduce the problem here with the following code:
var i: Integer;
  TreeNodeShape1.Text.Clear;
  for i:=0 to 10 do
   TreeNodeShape1.Text.Add('Line ' + IntToStr(i));
What have I incorrectly understood?
Collinor
Post by Collinor » Thu Jul 24, 2014 5:42 am
You added an odd number of lines (0 to 10) to the shape. The following code reproduces the problem:
var i: Integer;
  for i:=1 to 10 do
Post by Yeray » Mon Aug 04, 2014 12:04 pm
Sorry for the confusion. I could reproduce the problem (so I added it to the public tracker B875) and also checked your suggestion fixes it, so I've implemented the change and the next maintenance release will include it.
