We are getting following message after installing TeeChartVCLFMXSOURCE-2016.18.exe
Can't load package DclTeePro924.bpl. Cannot load package 'Tee924.' It contains unit 'VCLTee.TeeConst', which is also contained in package 'Tee9240'.
Can't load package DclTeeMaker124. Cannot load package 'Tee924.' It contains unit 'VCLTee.TeeConst', which is also contained in package 'Tee9240'.
Can't load package DclTree2D24Tee9. Cannot load package 'Tee924.' It contains unit 'VCLTee.TeeConst', which is also contained in package 'Tee9240'.
Windows 10 x64
Delphi 10.1
DevExpress VCL Products 15.2.6
QuickReport 5.06 Professional
TsiLang Components Suite 7.5.3.0
Any idea?
Re: Cannot load package 'Tee924.'
Hello
The error message "Cannot load package Tee9XX. It contains unit *, which is also contained in package Tee9XX0" indicates that the TeeChart package that was shipped with the IDE (Tee9XX0) is still trying to be loaded, and this creates a conflict with the version you've just installed.
Note XX above refers to the IDE number. 24 for RAD 10.1 Berlin, 23 for RAD 10 Seattle, 22 for RAD XE8, 21 for RAD XE7, 20 for RAD XE6, 19 for RAD XE5, 18 for RAD XE4,...
There are two possible causes and solutions for this error:
- If the TeeChart Standard package shipped with the IDE (Tee9XX0) is present and selected in the list of packages in the IDE, please uncheck it. Then you should be able to select the TeeChart Pro/Std commercial package (Tee9XX) in the same list.
- There are some 3rd party tools (*) that can be referencing the TeeChart Standard package shipped with the IDE, and thus causing this conflict. Please try to uncheck temporally any 3rd party tool package you may have installed in the list of packages to try to identify which one is causing the conflict.
(*) Some known 3rd party tools using TeeChart Standard are: FastReports, DevExpress and ReportBuilder.
Steema Software supports the integration of TeeChart into QuickReport and IntraWeb. Any other integration is supported by the 3rd party tool manufacturer.
Thanks, only partially helpful, unchecking other products makes no difference, uninstalling DevExpress and FastReports works (at least no problems yet), but FastReports does not install again.
Still, calling for better error messages..![Very Happy :D](./images/smilies/icon_biggrin.gif)
