Bug 2460 - Chart does not render correctly when compiles with RAD Studio 11 works in RAD studio 10
Summary: Chart does not render correctly when compiles with RAD Studio 11 works in RAD...
: High critical
Assignee: yeray alonso
Reported: 2021-09-19 14:02 EDT by SwingView Pro
Modified: 2022-09-20 10:03 EDT (History)
3 users (show)
Chart Series: Contour
Screen Shots of rendering issue (452.92 KB, application/pdf)
2021-09-19 14:02 EDT, SwingView Pro
Sample project the exhibits the behavior. (76.12 KB, application/zip)
2021-09-20 15:31 EDT, SwingView Pro
Removed some libs that are not needed from the project. (75.74 KB, application/zip)
2021-09-20 16:23 EDT, SwingView Pro
Description SwingView Pro 2021-09-19 14:02:22 EDT
Created attachment 980 [details]
I took the same code that works fine in RAD Studio 10 and compiled in the new RAD Studio 11.  I install the latest TeeChart components (33.210915) for the RAD Studio 11.  I compiled the code with not changes.  The chart does not render correctly as shown by the attachments. The background is blanked out.
Comment 1 yeray alonso 2021-09-20 04:05:51 EDT
I've tested the following code in both RAD 10.4 + TeeChart 2021.32 and RAD 11 + TeeChart 2021.33, and I've got no gradient in any of them.
uses VCLTee.Chart, VCLTee.TeeSurfa, VCLTee.TeeConst, VCLTee.TeeGDIPlus;
var Chart1: TChart;
  Caption:=TeeMsg_Version;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Chart1.Axes.Bottom.SetMinMax(0, 11);
  Chart1.Axes.Left.SetMinMax(0, 11);
  with TContourSeries(Chart1.AddSeries(TContourSeries)) do
    FillSampleValues;
    Filled:=True;
However, adding this to the code, makes the gradients to appear in both environments:
  Chart1.Gradient.Visible:=True;
  Chart1.Gradient.EndColor:=clGray;
  Chart1.Walls.Back.Transparent:=False;
  Chart1.Walls.Back.Gradient.Visible:=True;
  Chart1.Walls.Back.Gradient.StartColor:=clGray;
  Chart1.Walls.Back.Gradient.EndColor:=clWhite;
I'll close this as "invalid" for the moment.
If you still find problems with it, please arrange a simple example project we can run as-is to reproduce the problem here.
Comment 2 SwingView Pro 2021-09-20 15:29:19 EDT
Here is a C++ project the exhibits the issue.  Just double click on the chart to load the data file for the chart.  The ChartData.sfp should is in the debug folder.
Comment 3 SwingView Pro 2021-09-20 15:31:03 EDT
Created attachment 981 [details]
Double click on the chart to load the chart data.
Comment 4 SwingView Pro 2021-09-20 16:23:21 EDT
Created attachment 982 [details]
Comment 5 marc meumann 2021-09-21 11:05:06 EDT
We're looking at this. The minimum palette colour is black in this example, that is rendering in the latest version of the code, didn't in previous version (to be revised).
Try this workaround code:
uses System.UITypes;
    with TContourSeries(Chart1[0]) do
      Levels.Items[0].Color := TAlphaColor($FFFFFFFF); //transparent
Comment 6 SwingView Pro 2021-09-21 16:49:51 EDT
The work around setting the first color to transparent works.
