Bug 2110 - Calculation for Skewness and Kurtosis using TSeriesStatsTool
Summary: Calculation for Skewness and Kurtosis using TSeriesStatsTool
Status: IN_PROGRESS
Version: 19.161025
Reported: 2018-10-06 23:30 EDT by Nina Kajiji
Modified: 2023-03-16 15:22 EDT (History)
Chart Series: FastLine
Delphi / C++ Builder RAD IDE Version: RAD XE8
Contains the data and a snapshot of the output and TeeChart code (44.95 KB, application/vnd.openxmlformats-officedocument.spreadsheetml.sheet)
2018-10-06 23:30 EDT, Nina Kajiji
test xls and report pdf (489.57 KB, application/x-zip-compressed)
2018-10-22 03:42 EDT, yeray alonso
Small test project (2.56 KB, application/x-zip-compressed)
2023-03-16 15:22 EDT, david berneda
Description Nina Kajiji 2018-10-06 23:30:01 EDT
Created attachment 863 [details]
The calculation of Skewness and Kurtosis using the TSeriesStatsTool is giving different answers compared to that of SAS (with vardef=df option), SPSS and Excel. All three provide comparable numbers. The mean and standard deviation calculations from TeeChart are comparable to that of the statistical programs.
I am including an .XLS file with the data I am using. The Teechart code is also attached.
Teecharts answers are:
Skewness = 0.916
Kurtosis = 3.658
Excels answers are:
Skewness = 0.965
Kurtosis = 1.032
I also show the traditional calculation for Kurtosis which appears in  textbooks such as Snedecor and Cochran (1967). By that method the calculation should be 3.7544.
So I am not sure what formulas are being used in Teechart. I would really appreciate if you could clarify the computational differences I observe.
Nina
Comment 1 yeray alonso 2018-10-22 03:42:36 EDT
Created attachment 865 [details]
I attack here the test xls and the report from Nina Kajiji.
Thanks for the analysis!
Comment 2 david berneda 2023-03-16 15:17:14 EDT
In progress.
Adding support for "Complete" calculation. This code was created without considering the different alternatives, so originally the Std Deviation was only used at the end of the calculation, not while accumulating the sum of differences.
Still not totally correct, pending to check.
    with Series,MandatoryValueList do
    if Count>0 then
       tmpMean:=Total/Count
       tmpMean:=0;
    for t:=0 to Series.Count-1 do
      tmp:=(Series.MandatoryValueList.Value[t]-tmpMean);
      // https://www.steema.com/bugs/show_bug.cgi?id=2110
      if Complete then
         tmp:=tmp/tmpStdDeviation;
      result:=result+Power(tmp,Exponent);
Comment 3 david berneda 2023-03-16 15:22:11 EDT
Created attachment 1038 [details]
Small test project
Test project with the same data of the Excel sheet.
