Bug 200 - [TV52015093] Changing the series Brush with GetTeeBrush in a chart with four condi...
Summary: [TV52015093] Changing the series Brush with GetTeeBrush in a chart with four ...
Reported: 2010-08-17 19:48 EDT by yeray alonso
Modified: 2013-11-20 10:03 EST (History)
Description yeray alonso 2013-11-20 10:03:13 EST
Changing the series Brush with GetTeeBrush in a chart with four conditions, when you repaint the chart, the panel has the brush you set to the series. Works fine in D7 but occurs in D2010
The conditions are remarked in the code.
uses Series, TeeBrushDlg;
var i: integer;
 bmp: TBitmap;
 Chart1.RemoveAllSeries;
 Chart1.AddSeries(TBarSeries.Create(self));
 Chart1[0].ParentChart := Chart1;
Chart1[0].Marks.Visible := false; // Removing these code lines will avoid generating a "strange looking" graph
 Chart1.Color := clwhite; // Removing these code lines will avoid generating a "strange looking" graph
 Chart1.View3D := false; // Removing these code lines will avoid generating a "strange looking" graph
 Chart1.Gradient.Visible := false; // Removing these code lines will avoid generating a "strange looking" graph
for I := 0 to 9 do
 with Chart1[0] as TBarSeries do
 addbar(i,inttostr(i),clred);
bmp := TBitmap.create;
 GetTeeBrush(0,bmp);
 BarBrush.Image.Assign(bmp);
bmp.Free;
Chart1.Draw;
end; [created:2010-08-17T18:48:14.000+01:00 reported by:yeray@steema.com reported in version:9.0 (TeeChart VCL)]
