Bug 1820 - Side by Side Bars overlap
Summary: Side by Side Bars overlap
Product: FireMonkey TeeChart
Reported: 2017-03-16 10:18 EDT by yeray alonso
Modified: 2021-04-21 05:29 EDT (History)
Chart Series: Bar
Delphi / C++ Builder RAD IDE Version: RAD 10.1 Berlin
test project (1.47 KB, application/x-zip-compressed)
2017-03-16 10:18 EDT, yeray alonso
Description yeray alonso 2017-03-16 10:18:28 EDT
Created attachment 735 [details]
test project
As the customer shows in a screenshot, some of the bars overlap when side by side.
See the attached project.
It looks as if the bars were drawn in the wrong order.
Works fine in VCL.
Comment 1 sandra pazos 2017-06-07 06:55:46 EDT
Update.
The problem occurs when is set the Xvalues property Order to Descending.   E.g:
Chart1[0].XValues.Order := loNone;
Chart1[1].XValues.Order := loDescening;
Comment 2 yeray alonso 2017-06-08 03:28:11 EDT
The problem appears when you set a Descending order to the XValues on the second bar series. Also happens in VCL:
uses Series;
var Series1, Series2: TBarSeries;
  Series1:=Chart1.AddSeries(TBarSeries) as TBarSeries;
  Series1.FillSampleValues;
  Series2:=Chart1.AddSeries(TBarSeries) as TBarSeries;
  Series2.XValues.Order := loDescending;
  Series2.FillSampleValues;
The workaround is to set the order back to Ascending:
  Series2.XValues.Order:=loAscending;
  Series2.XValues.Sort;
  Chart1.Repaint;
