Bug 1679 - Adding a new series messes up the custom palette
Summary: Adding a new series messes up the custom palette
Status: IN_PROGRESS
Version: 20.170306
Reported: 2016-11-08 08:44 EST by h.hasenack
Modified: 2017-03-14 05:27 EDT (History)
Description h.hasenack 2016-11-08 08:44:14 EST
When adding a new tchartsieres to an existing chart that utilkizes a custom palette, the pallette is destroyed adn an standard palette is restored.
Comment 1 h.hasenack 2016-11-08 08:46:15 EST
Here's the fix, in TeeGally.pas mared with HH_PATCH_REGISTERPALETTE
Function CreateNewSeriesGallery( const AOwner:TComponent;
                                 const OldSeries:TChartSeries;
                                 const tmpChart:TCustomAxisPanel;
                                 ShowFunctions,
                                 CheckSeries:Boolean;
                                 Var SubIndex : Integer;
                                 AGalleryWidth: Integer=0;
                                 AGalleryHeight: Integer=0  ):TChartSeries;
  function InternalShowGallery:TChartSeries;
  var Show3D   : Boolean;
      tmpClass : TChartSeriesClass;
      tmpFunctionClass : TTeeFunctionClass;
      tmpPalette : Integer;
{$ifdef HH_PATCH_REGISTERPALETTE}
      tmpColorPalette:TColorArray;
{$endif}
      tmpOwner : TComponent;
    result:=nil;
    Show3D:=tmpChart.View3D;
    tmpPalette:=(tmpChart as TCustomChart).ColorPaletteIndex;
    tmpColorPalette:=(tmpChart as TCustomChart).ColorPalette;
{$endif}
    //If we show the gallery from the chart editor we use its gallery size
    if (AOwner is TChartEditForm) and
       (TChartEditForm(AOwner).GalleryWidth>0) and
       (TChartEditForm(AOwner).GalleryHeight>0) then
      AGalleryWidth:=TChartEditForm(AOwner).GalleryWidth;
      AGalleryHeight:=TChartEditForm(AOwner).GalleryHeight;
    if GetChartGalleryClass(AOwner,OldSeries,ShowFunctions,tmpClass,Show3D,
                            tmpFunctionClass,CheckSeries,SubIndex,
                            tmpPalette, AGalleryWidth, AGalleryHeight,
                            tmpChart) then
      tmpChart.View3D:=Show3D;
      (tmpChart as TCustomChart).ColorPaletteIndex:=tmpPalette;
      if tmpPalette<0 then // restore custom palette
        (tmpChart as TCustomChart).ColorPalette:=tmpColorPalette;
{$endif}
      if (not Assigned(OldSeries)) or
         (ShowFunctions or ((tmpClass<>OldSeries.ClassType) or (SubIndex<>-1))) then
        if Assigned(OldSeries) then tmpOwner:=OldSeries.Owner
                               else tmpOwner:=TCustomAxisPanelAccess(tmpChart).GetDesignOwner;
        result:=CreateNewSeries(tmpOwner,tmpChart,tmpClass,tmpFunctionClass);
        if SubIndex<>-1 then
           TSeriesAccess(result).SetSubGallery(result,SubIndex);
  try
    result:=InternalShowGallery;
  except
    on E:Exception do
      {$IFDEF TEEEXCEPTIONS}
      if csDesigning in tmpChart.ComponentState then
         TTeeExceptionForm.Send('GALL',E);
      {$ENDIF}
      raise;
