Clipping problem with Chart1.Canvas.LineTo & AfterDrawVa
pssdelphi
Post by pssdelphi » Tue Dec 19, 2006 8:04 pm
I have a pointer series on a chart, and I am drawing custom lines from certain points to others (not like the sequential point to point ones that are built in). The lines draw fine and scroll with the chart but they do not clip at the axis like the points in the series do. How can I get my custom lines to clip like the points in the series do?
procedure TForm1.Series1AfterDrawValues(Sender: TObject);
var x0, y0, x1, y1, x2, y2 : Integer ;
Chart1.ClipPoints:=true;
x0:=Series1.CalcXPos(0);
y0:=Series1.CalcYPos(0);
x1:=Series1.CalcXPos(1);
y1:=Series1.CalcYPos(1);
x2:=Series1.CalcXPos(2);
y2:=Series1.CalcYPos(2);
Chart1.Canvas.MoveTo( x0, y0 );
Chart1.Canvas.LineTo( x1, y1 );
Chart1.Canvas.LineTo( x2, y2 );
Thanks in advance,
David
Post by Pep » Sat Dec 23, 2006 1:26 pm
Hi David,
you can do :
implementation
{$R *.dfm}
Series1.BeforeDrawValues:=SeriesBeforeDraw;
procedure TForm1.SeriesBeforeDraw(Sender: TObject);
  Function SeriesRect(Series:TChartSeries):TRect;
    With result do
      Left:=Series.GetHorizAxis.IStartPos;
      Right:=Series.GetHorizAxis.IEndPos;
      Top:=Series.GetVertAxis.IStartPos;
      Bottom:=Series.GetVertAxis.IEndPos;
  // Clip
  With Chart1 do
       if CanClip then
          Canvas.ClipRectangle(SeriesRect( Sender as TChartSeries ));
end.
pssdelphi
Post by pssdelphi » Sun Dec 31, 2006 3:35 am
Re: Clipping problem with Chart1.Canvas.LineTo & AfterDrawVa
Post by Marc » Thu Jul 01, 2021 9:15 am
Update to previous answer. The Clip in OnAfterDraw should apply to the Chart rectangle.
ie.
Chart1.Canvas.ClipRectangle(Chart1.ChartRect);  //<--here
x1:=Series1.CalcXPos(20); ...etc
Chart1.Canvas.UnClipRectangle;
