Disable Live Bindings
Winweb
Post by Winweb » Tue Mar 14, 2017 2:24 pm
I've disabled Live Bindings in Delphi 10.1.. It did this because of massive performance problems in bigger projects. I did it the following way: Removed / disabled the three Live Bindings packages from embarcadero.
Since it did that TeeChart Pro complains at every start about it: "Error registering TeeChart LiveBindings: Invalid registration". I tried to bypass this with reinstalling the TeeChart components, but i had no success.
Is there anyway to disable / get rid of live bindings in teechart pro, too?
Greetings from Germany
Re: Disable Live Bindings
Post by Yeray » Wed Mar 15, 2017 8:20 am
I'm not sure if this is the best workaround but it's worth to give it a try:
- Delete BindCompFMXTeeReg.dcu and BindCompVCLTeeReg.dcu from "Delphi24\Delphi24.win32\Lib" folder.
- Run TeeInstall.exe from "Delphi24" folder, and select "No" when asked to Uninstall the product (this will reinstall it).
Winweb
Post by Winweb » Wed Mar 15, 2017 9:04 am
Thank you for your suggestion. I tried it the way you described it, but without success. :?
rcarn
Post by rcarn » Mon Mar 27, 2017 2:54 pm
Same issue. Please describe how to disable the teechart message when the Delphi livebindings package has been renamed/removed.
Post by Yeray » Tue Mar 28, 2017 12:18 pm
We are fixing this at least for source code customers, and we'll see if we can also fix it for the binary installations.
rcarn
Post by rcarn » Tue Mar 28, 2017 8:35 pm
Thank you. Please let us know the resolution. I just bought TeeChart; perhaps I'd be allowed to "upgrade" to source if that's necessary to eliminate livebindings.
Post by Yeray » Mon Apr 03, 2017 7:59 am
We've added a checkbox in TeeRecompile to allow disabling LiveBindings. TeeRecompile is the tool shipped with the source code version that helps compiling and installing the components into the IDEs.
For the moment, those customers without the sources who are interested in disabling LiveBindings, please let us know what IDE you are using and we'll provide a special non-LiveBindings install.
rcarn
Post by rcarn » Mon Apr 03, 2017 1:27 pm
Delphi 10.1 Berlin Pro
Post by Yeray » Tue Apr 04, 2017 8:37 am
rcarn wrote:Delphi 10.1 Berlin Pro
I'm sending a mail with the link with the private test install to the mail account you have registered in this forum.
Winweb
Post by Winweb » Wed Apr 05, 2017 5:22 am
Im using also Delphi 10.1 Upd.2 Pro
Can you please send me also the private install file?
Winweb
Post by Winweb » Wed Apr 05, 2017 5:30 am
I can't find any checkbox in the recompile tool
Post by Yeray » Wed Apr 05, 2017 7:16 am
Winweb wrote:I can't find any checkbox in the recompile tool
I'm afraid the new checkbox didn't get into the v2017.21 release.
I'll send you a mail with the current TeeRecompile version.
Fab
Post by Fab » Fri May 12, 2017 11:07 pm
Same problem for me.
I use Delphi XE 10.1 Berlin enterprise version (update 2).
But I'am registered on a Teechart + source
Best regards,
Fabrice
Post by Yeray » Mon May 15, 2017 6:20 am
Fab wrote:Same problem for me.
I've just sent you a mail with the same file.
Fab
Post by Fab » Fri May 19, 2017 8:55 am
I have recompiled Teechart with the new option Livebindings disabled and it's work fine.
Now I can disable Livebindings on Delphi !
Thank you for your quick answer and solution.
