How can I ReCompile Teechart 2013 pro for VCL Under the XE3
smp
Re: How can I ReCompile Teechart 2013 pro for VCL Under the XE3
Post by smp » Wed Oct 09, 2013 9:32 am
Hi Yeray Alonso:
When I run TeeRecompile.exe in Simple Chinese OS(without Decison cube), after I modified the Error of TeeConst.pas, I got the error info like these:
    TeeChart Pro
    Compilation started: 2013-10-9 16:48:49
    Win32 v17 Architect
    Tee917
    Embarcadero Delphi for Win32 compiler version 24.0
    Copyright (c) 1983,2012 Embarcadero Technologies, Inc.
    77110 lines, 0.64 seconds, 678164 bytes code, 4308 bytes data.
    TeeUI917
    Cannot recompile Delphi package: TeeUI917.dpk
    VCLTee.TeeFormatting.pas(230) Error: E2052 Unterminated string
    VCLTee.TeeFormatting.pas(231) Error: E2029 ')' expected but identifier 'CBGeo' found
    VCLTee.TeExport.pas(515) Fatal: F2063 Could not compile used unit 'VCLTee.TeeFormatting.pas'
    EXCEPTION:
    Compilation aborted.
and then I run Teecompile.exe with Decison cube, I got errors like these:
      TeeChart Pro
      Compilation started: 10/9/2013 1:43:42 AM
      Win32 v17 Architect
      Tee917
      77110 lines, 0.99 seconds, 678176 bytes code, 4308 bytes data.
      TeeUI917
      64098 lines, 0.65 seconds, 446060 bytes code, 1128 bytes data.
      TeeDB917
      7964 lines, 0.53 seconds, 62248 bytes code, 284 bytes data.
      TeePro917
      184885 lines, 0.89 seconds, 1187016 bytes code, 6380 bytes data.
      TeeGL917
      14181 lines, 0.25 seconds, 118000 bytes code, 3072 bytes data.
      TeeImage917
      23540 lines, 0.28 seconds, 279780 bytes code, 11360 bytes data.
      TeeWorld917
      2289 lines, 0.48 seconds, 17764 bytes code, 268 bytes data.
      TeeLanguage917
      81387 lines, 0.38 seconds, 3454640 bytes code, 3548 bytes data.
      DclTee917
      7909 lines, 0.92 seconds, 148684 bytes code, 348 bytes data.
      DclTeePro917
      11852 lines, 0.50 seconds, 215340 bytes code, 512 bytes data.
      DclTeeProStd917
      7245 lines, 0.52 seconds, 194124 bytes code, 500 bytes data.
      TeeMaker117
      82824 lines, 0.49 seconds, 826936 bytes code, 12816 bytes data.
      DclTeeMaker117
      83610 lines, 0.80 seconds, 18352 bytes code, 204 bytes data.
      FMXTee917
      72964 lines, 1.09 seconds, 636968 bytes code, 4044 bytes data.
      FMXTeeUI917
      29231 lines, 0.43 seconds, 337168 bytes code, 768 bytes data.
      FMXTeeDB917
      5686 lines, 0.27 seconds, 62552 bytes code, 284 bytes data.
      FMXTeePro917
      120181 lines, 1.09 seconds, 1116356 bytes code, 5696 bytes data.
      FMXTeeLanguage917
      80975 lines, 0.42 seconds, 3454224 bytes code, 3548 bytes data.
      DclFMXTee917
      4126 lines, 0.65 seconds, 114160 bytes code, 268 bytes data.
      DclFMXTeePro917
      5964 lines, 0.51 seconds, 139196 bytes code, 288 bytes data.
      DclFMXTeeProStd917
      5011 lines, 0.53 seconds, 121020 bytes code, 284 bytes data.
      Compilation started: 10/9/2013 1:44:05 AM
      TeeTree2D17Tee9
      45372 lines, 0.30 seconds, 605280 bytes code, 1496 bytes data.
      DclTree2D17Tee9
      1416 lines, 0.47 seconds, 14564 bytes code, 240 bytes data.
      TeeChart Installation
      VERSION: 2013
      Installing...
      EXCEPTION:
      Cannot recompile Decision Cube packages under Delphi 17
Any idea?
Post by Yeray » Thu Oct 10, 2013 12:16 pm
smp wrote:When I run TeeRecompile.exe in Simple Chinese OS(without Decison cube), after I modified the Error of TeeConst.pas, I got the error info like these:
In the line 230 in TeeFormatting.pas I read:
CBGeo.Items.Add('ddd°');
Are you seeing any strange symbol? Any '?' symbol?
smp wrote:and then I run Teecompile.exe with Decison cube, I got errors like these:
We'll investigate it.
smp
Post by smp » Thu Oct 10, 2013 1:25 pm
Yes, there is a '? under the line, Simple Chinese OS can't compile the "°".that's not the same with my language.
temorrow, I'll repair it and retry?
thanks.
