TChart serializable problem
rubby
Re: TChart serializable problem
Post by rubby » Wed Jan 22, 2014 2:06 pm
Hello, Marc .
I got it. Thanks.
For the export and import problem,
Could you please run my code example , if it can not start, please let me know.
If you can run the code example, could you please try to click operation--> save.
Then click operation--> load.
I think you will find that something is wrong.
If you can load the saved tej or xml correctly, please let me know too.
I have tried many times, the tej can not loaded correctly.
Thanks again .
Post by Yeray » Fri Jan 24, 2014 4:58 pm
I've ran your application (well, I moved the code to a NetBeans application but it's pretty much your code).
I've been able to reproduce the error you reported here when exporting to XML. We are investigating it.
However, I've been able to export and import the chart using tej without many problems. I've only modified/corrected a few things:
- I've commented the initialization of the chart size because I've placed the chart at design time so it already has a size:
//tChart1.setBounds(new Rectangle(0, 0, 500, 500));
- In saveItem button, I've uncommented the line where you are exporting the chart to a tej and I've commented the line where you export the chart to an xml. Also, I've slightly changed the path:
tChart1.getExport().getTemplate().toFile("c:\\tmp\\tt23.tej");
//tChart1.getExport().getTemplate().toXML("c:\\tmp\\tt23.xml");
- In saveItem button I've commented the line where you set a text to the first label. note you are doing this after clearing the labels, so it gives an IndexOutOfBoundsException. I've also commented the repaint:
 bottom.getLabels().getItems().clear();
/*bottom.getLabels().getItems().set( 0, "new-1");
tChart1.repaint();*/
Here you have the complete saveItem action:
        saveItem.addActionListener(new ActionListener() {
            public void actionPerformed(ActionEvent e) {
                if (tChart1 != null) {
                    try {
                        tChart1.setText("Stored chart");
                        tChart1.getSeries(0).setTitle("StoreA");
                        tChart1.getSeries(1).setTitle("StoreB");
                        Axis bottom = tChart1.getAxes().getBottom();
                        System.out.println(bottom.getLabels().getItems().size());
                        bottom.getLabels().getItems().add((double) 1, "MyXLabel-1");
                        bottom.getLabels().getItems().add((double) 2, "MyXLabel-2");
                        tChart1.repaint();
                        JOptionPane.showMessageDialog(null, "Current tchart will be stored");
                        tChart1.getAspect().setView3D(true);
                        tChart1.setText("New Chart");
                        tChart1.getSeries(0).setTitle("new A");
                        tChart1.getSeries(1).setTitle("new B");
                    } catch (IOException ex) {
- I've modified the openItem button to import the tej and I've added the refreshControl call mentioned previously.
        openItem.addActionListener(new ActionListener() {
                    try {
                        tChart1.setChart(tChart1.getImport().getTemplate().fromFile("c:\\tmp\\tt23.tej")); //load fail
                        //tChart1.getImport().getTemplate().fromXML("c:\\tmp\\tt23.xml");
                        //tChart1.updateUI();
                        //tChart1.repaint();
                        tChart1.refreshControl();
                    } catch (Exception ex) {
rubby
Post by rubby » Sun Jan 26, 2014 1:55 pm
Hello, Yeray:
Thank you so much.
For the export and import tej,
I should use:
tChart.setChart( tChart.getImport().getTemplate().fromFile("c:\\tt23.tej"));
instead of
  tChart.getImport().getTemplate().fromFile("c:\\tt23.tej");
this is why can not import a tej and show it.
However, for xml,
both of them are ok.
                        tChart.getImport().getTemplate().fromXML("c:\\tt23.xml") ; //this is ok
                      tChart.setChart(tChart.getImport().getTemplate().fromXML("c:\\tt23.xml")); //this is ok too
For currently xml export and import, there is some errors with it.
java.lang.NullPointerException
at com.steema.teechart.drawing.Gradient.getCustomTargetRectangle(Gradient.java:448)
This will result the "MyXLabel-1" and "MyXLabel-2" do not showed.
I hope this conclusion will benefit other guys who come across similar problem.
In fact, i have another question, sorry.
Can i add some custom properties defined by myslef into xml or tej?
for example the created date, the author of this tchart, the data source path to create this tej.
thanks.
Post by Yeray » Tue Jan 28, 2014 9:41 am
rubby wrote:I hope this conclusion will benefit other guys who come across similar problem.
+1! Thanks for sharing.
rubby wrote:Can i add some custom properties defined by myslef into xml or tej?
Yes, being a source code customer allows you to add any property you like to the TChart and they will be exported/imported with the other properties.
