Problem with Bar
rubby
Problem with Bar
Post by rubby » Thu Aug 29, 2013 3:26 am
my code looks like:
TChar tchart2 = new TChart();
tchart2.addSeries(new Bar());
tchar2.getSeries(0).add(10);
tchar2.getSeries(1).add(18);
tchar2.getSeries(2).add(30);
Finally, only the first series is showed.
That is, only one bar is showed. There must be three bars.
Does anyone know how to address this?
rubby
Re: Problem with Bar
Post by rubby » Fri Aug 30, 2013 3:08 am
my code is as follows.
In the bar.png, you will find there is only one bar which is wrong.
import com.steema.teechart.Dimension;
import com.steema.teechart.Rectangle;
import com.steema.teechart.editors.ChartEditor;
import com.steema.teechart.styles.Bar;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.JDialog;
import javax.swing.JMenuItem;
import javax.swing.JPopupMenu;
 * @author
public class TestTeeChartJunit extends JDialog {
    public TestTeeChartJunit() {
        this.setDefaultCloseOperation(JDialog.DISPOSE_ON_CLOSE);
        setSize(new Dimension(581, 380));
        setTitle("TeeChart for Java - Swing example application");
        tChart2 = new TChart();
        tChart2.setGraphics3D(null);
//        tChart2.addSeries(new Line());
//        tChart2.getSeries(0).fillSampleValues(); //随机数
        tChart2.addSeries(new Bar());
        tChart2.getSeries(0).add(10);
        tChart2.getSeries(1).add(13);
        tChart2.getSeries(2).add(49);
        tChart2.getSeries(3).add(55);
        tChart2.setBounds(new Rectangle(0, 0, 500, 500));
        //设置图标的属性
        tChart2.getAspect().setView3D(false); // no 3D
        // tChart2.getLegend().setText("jw legend");
        this.add(tChart2);
        tChart2.setComponentPopupMenu(popup);
        JMenuItem item = new JMenuItem("Property");
        item.addActionListener(new RightListener(tChart2));
        popup.add(item);
        this.setVisible(true);
        TestTeeChartJunit myChart = new TestTeeChartJunit();
    TChart tChart2;
    JPopupMenu popup = new JPopupMenu();
class RightListener implements ActionListener {
    TChart tChart2 = null;
    public RightListener(TChart chart) {
        this.tChart2 = chart;
    public void actionPerformed(ActionEvent e) {
        ChartEditor.editChart(tChart2.getChart());
Post by Yeray » Fri Aug 30, 2013 12:18 pm
That's a problem already present in the defect list to be fixed for further releases (TJ71016295).
I've incremented the ticket priority.
rubby
Post by rubby » Tue Sep 24, 2013 2:26 am
hello,
I find an approach to avoid this problem by
chart.getAspect().setView3D(true)
does there exists some other approaches to avoid this problem?
e.g. set bigger distance between each bar? or something else?
rubby
Post by rubby » Tue Sep 24, 2013 3:08 am
luckily, i find a perfect approach to avoid the bar problem which is very common and confuse the users always.
(Bar)chart.getSeries(i).setMultiBar(MultiBars.SIDEALL)
:P
