Shadow color for header?
znakeeye
Post by znakeeye » Sat Mar 02, 2013 10:35 pm
http://stackoverflow.com/questions/1414 ... n-teechart
TJ71016479
Will this be added in the maintenance release? This feature is very important for me!
Re: Shadow color for header?
Post by Yeray » Tue Mar 05, 2013 9:24 am
I've revised it and I found a fix for it. So yes, the next maintenance release will include this fix.
znakeeye
Post by znakeeye » Tue Mar 12, 2013 10:21 pm
Could you please share the patch for this bug?
znakeeye
Post by znakeeye » Tue Mar 12, 2013 10:37 pm
This is what I came up with. Correct?
protected void drawString(int x, int y, final String text, final ChartBrush brush) {
		// FIX:
		Paint fontPaint = brush.getPaint();
		fontPaint.setTextSize(font.getSize() * (float)(chart.getAspect().getFontZoom() * 0.01));
		// Paint fontPaint = font.getPaint((float) (chart.getAspect().getFontZoom() * 0.01));
Post by Yeray » Wed Mar 13, 2013 11:19 am
The fix I applied was a bit different but your suggestion looks better to me. The next maintenance release will include it.
znakeeye
Post by znakeeye » Wed Mar 13, 2013 8:05 pm
I'm wondering if you should also set these:
fontPaint.setTypeface(font.getTypeFace()); // getTypeFace() needs to be implemented
fontPaint.setUnderlineText(font.getUnderline());
fontPaint.setStrikeThruText(font.getStrikeout());
Post by Yeray » Mon Mar 18, 2013 1:40 pm
Right, the fix you suggested breaks these properties.
The fix I initially used doesn't, so it could be better to use it:
		final Paint fontPaint = font.getPaint((float) (chart.getAspect().getFontZoom() * 0.01));
		fontPaint.getTextBounds(text, 0, text.length(), textBounds);
		textSize.width=textBounds.width()+2;
		textSize.height=getFontHeight();
		//TJ71016479
		if (fontPaint.getColor() != brush.getColor().getRGB())
			fontPaint.setColor(brush.getColor().getRGB());
