Problems with Chart1.Axes.Bottom.Items.Clear;
Friis
Post by Friis » Mon Feb 18, 2013 10:44 am
When I change between TAxisLabelSTyle "TalValue" and "TalMark" and also using the Chart1.Axes.Bottom.Items.Clear; method I have problems with the bottom axis - it simply disappears.
Try the following: (see code below)
1) Press button1 once (bottom axis TAxisLabelSTyle is talValue; it works fine)
2) Press button2 once (bottom axis TAxisLabelSTyle is talMark; it works fine)
3) Press button1 once (bottom axis TAxisLabelSTyle is talValue; it does NOT work - the values at the bottomaxis disappears)
It seems that the problem is with "Chart1.Axes.Bottom.Items.Clear;" - When that command has been called; then there is problems...
Put a TChart (name Chart1) and two buttons, Button1 and Button2 on a Form:
procedure TForm10.Button1Click(Sender: TObject);
var i: Integer;
Chart1.FreeAllSeries();
Chart1.RemoveAllSeries;
  Chart1.View3D:=false;
  Chart1.AddSeries(TFastLineSeries);
  for i:=0 to 10 do
    Chart1[0].AddXY(i, i, 'label ' + IntToStr(Chart1[0].Count));
    Chart1[1].AddXY(i+0.5, i+10, 'label ' + IntToStr(Chart1[1].Count));
  Chart1.BottomAxis.LabelStyle := TalValue;
procedure TForm10.Button2Click(Sender: TObject);
var i: Integer;
  for i:=0 to 10 do
  for i:=0 to Chart1[0].Count-1 do
    if Chart1[0].Labels[i]<>'' then
      Chart1.Axes.Bottom.Items.Add(Chart1[0].XValue[i], Chart1[0].Labels[i]);
Re: Problems with Chart1.Axes.Bottom.Items.Clear;
Post by Yeray » Mon Feb 18, 2013 11:24 am
Items.Clear activates the custom labels list and clears it. It is thought to be used before Items.Add.
If you just want to use the regular automatic labels instead of the items list, try setting automatic:=true:
Chart1.Axes.Bottom.Items.Automatic:=true;
