problems with TGanttSeries and LeftAxis Labels
Friis
Post by Friis » Tue Dec 04, 2012 10:08 am
When making the code below, The marks seems to interfere with the LeftAxis Labels. I have attached a figure illustraing the problem. How can I avoid that??
procedure TForm10.FormShow(Sender: TObject);
var
  I: Integer;
Chart1.View3D := false;
     with Chart1.AddSeries(TGanttSeries.Create(self)) as TGanttSeries do
          ParentChart := Chart1;
          ShowInLegend := true;
          XValues.Order:=loNone;
          ShowInLegend := false;
          Marks.visible := true;
          Marks.Transparent := true;
          Xvalues.DateTime := true;
      for I := 0 to 9 do
        with Chart1[Chart1.SeriesCount -1] as TGanttSeries do
            Pointer.VertSize:=10;
            AddGanttcolor(now-5-i,now-5+i,i div 2,'',clred);
chart1.BottomAxis.SetMinMax(now-5,now+10);
Friis
Re: problems with TGanttSeries and LeftAxis Labels
Post by Friis » Tue Dec 04, 2012 10:09 am
The problem seems to be related to the problem with
Post by Yeray » Tue Dec 04, 2012 2:33 pm
Friis wrote:How can I avoid that??
It depends. How do you want to avoid that?
- Do you want the left axis labels not to be drawn? You can hide them setting a blank space in the string given at the OnGetAxisLabel event. Here it is a .NET example, but the same applies to VCL.
- Do you want the gantt marks to be drawn elsewhere? You can set a different bottom axis scale, or you can manually set the marks positions as shown here.
Friis
Post by Friis » Tue Dec 04, 2012 3:07 pm
Actually, what I would like is that, that part of the marks that are "outside" of the Chart area is not being shown. So that the area with the Left Axis Labels does not show the marks at all.
Post by Yeray » Tue Dec 04, 2012 3:42 pm
Hi Friis,
This is a clipping, isn't it? There's a property for it: Marks.Clip
  with Chart1.AddSeries(TGanttSeries) as TGanttSeries do
    OnGetMarkText:=GetMarkText;
    Marks.Clip:=true;
Friis
Post by Friis » Wed Dec 05, 2012 12:50 pm
I didn't know that property existed - Thank you; it works fantatsic know :D
