Vertical Autoresize to min/max on changing horizontal zoom
Miguel
Post by Miguel » Tue Feb 22, 2011 9:49 pm
Hello
I'm very thankful for the last response and solution, but now I have another question:
is it possible to do something like a vertical autoresize to min and max values when I change the zoom? I change the zoom like this:
chart.getAxes().getBottom().setMinimum(valuemin);
chart.getAxes().getBottom().setMaximum(valuemax);
or else, how can I know the points between this horizontal values? with that I could use the same instructions to resize vertically
Thanks in advance ! :)
Re: Vertical Autoresize to min/max on changing horizontal zoom
Post by Yeray » Thu Feb 24, 2011 5:02 pm
Hi Miguel,
I'm afraid you'll have to calculate it manually looping your series, searching for the minimum and maximum visible values. For example:
        tChart1.getAxes().getBottom().setMinMax(5, 15);
        tChart1.paint(tChart1.getGraphics());
        int firstVisible = line1.getFirstVisible();
        int lastVisible = line1.getLastVisible()-1;
        int minVisible = firstVisible;
        int maxVisible = firstVisible;
        for (int i=firstVisible;i<=lastVisible;i++)
            if (line1.getYValues().getValue(i) < line1.getYValues().getValue(minVisible))
                minVisible = i;
            if (line1.getYValues().getValue(i) > line1.getYValues().getValue(maxVisible))
                maxVisible = i;
        tChart1.getAxes().getLeft().setMinMax(line1.getYValues().getValue(minVisible), line1.getYValues().getValue(maxVisible));
Miguel
Post by Miguel » Thu Feb 24, 2011 6:51 pm
Hi Yeray
Thanks! the getFirstVisible(); function is just what I need
