Delphi 2006 /Intraweb 8 /TChart 7.12 Pro
TimH
Post by TimH » Wed Sep 26, 2007 6:26 pm
Hi - I have the above software and need to use TChart within my intraweb application - I have downloaded the IWTChart from the download area but can not install it - probally as its for delphi 7 and intraweb 7 - Is there a TChart component for intraweb 8 with Delphi 2006 ?
Tim
Post by Narcís » Thu Sep 27, 2007 9:32 am
Hi Tim,
We don't have such packages available. You should download the packages from http://www.steema.com/products/teechart ... raweb.html that are closer to your environment, change necessary package references, compile and install them.
TimH
TChart Intraweb
Post by TimH » Thu Sep 27, 2007 10:47 am
Downloaded this as suggested but it references Tee77.dcp Which i cant find anywhere ????
Post by Narcís » Thu Sep 27, 2007 11:14 am
Hi TimH,
As I told, you may need to change the TeeChart, IntraWeb and Delphi references. Tee77.dcp makes reference to TeeChart v7 for Delphi 7. If you are using Delphi 2006 you should change this reference to Tee710.dcp.
Hope this helps!
