All topic are empty
TeeGofer general
Locked
Robert van Poelgeest
All topic are empty
Post by Robert van Poelgeest » Tue May 18, 2004 4:54 pm
when i reopen a previously saved project all topics are empty. When i try Edit - Refresh i get:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at TeeGofer.MetaViewerForm.SaveExistingNodeInfo(Hashtable tmpNodeObjHashTable, Int32 Count)
at TeeGofer.MetaViewerForm.RefreshProjectContents()
at TeeGofer.MetaViewerForm.RefreshProject()
at TeeGofer.MetaViewerForm.menuItem7_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
TeeGofer
Assembly Version: 2.5.0.4
Win32 Version: 2.5.0.4
CodeBase: file:///C:/PROGRA~1/STEEMA~1/TEEGOF~1/TeeGofer.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/PROGRA~1/STEEMA~1/TEEGOF~1/AxInterop.SHDocVw.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
Interop.SHDocVw
CodeBase: file:///C:/PROGRA~1/STEEMA~1/TEEGOF~1/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.MSHelpServices
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/PROGRA~1/STEEMA~1/TEEGOF~1/Interop.MSHelpServices.DLL
CustomMarshalers
CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Hope this can be fixed soon (or a reasonable workaround) because this is a show stopper for us.
With kind regards,
Post by Christopher » Fri May 21, 2004 7:04 am
Hi Robert,
Mmmm, I'm having trouble reproducing this one as well. Would you be so kind as to specify the steps I have to take to do so?
Many thanks!
Thank you!
http://groups.google.com
http://codenewsfast.com/
Post by Robert van Poelgeest » Mon May 24, 2004 8:54 am
Hi Chris,
We load the assemblies from the obj\Release directory but the xml file is in the project directory itself. Also the different projects reference each other. If we use an installscript we use the following command:
cd "C:\Program Files\Steema Software\TeeGofer v2"
TeeGoCmd.exe /afn:"C:\DOT NET\1.1\MetaObjects\Framework\Uml\obj\release\MetaObjects.Framework.Uml.dll"+"C:\DOT NET\1.1\MetaObjects\Framework\obj\release\MetaObjects.Framework.dll"+"C:\DOT NET\1.1\MetaObjects\Framework\DataAccessLayer\Db\obj\release\MetaObjects.Framework.DataAccessLayer.Db.dll"+"C:\DOT NET\1.1\MetaObjects\Models\Core\PrimitiveObjects\obj\release\MetaObjects.Models.Core.PrimitiveObjects.dll"+"C:\DOT NET\1.1\MetaObjects\Models\Core\ComplexObjects\obj\release\MetaObjects.Models.Core.ComplexObjects.dll"+"C:\DOT NET\1.1\MetaObjects\Framework\Design\bin\Release\MetaObjects.Framework.Design.dll" /cma:"R.vanPoelgeest@metaobjects.net" /cn:"Robert van Poelgeest" /hv:version2 /crm:"2004 MetaObjects B.V." /df:MetaObjects.Models.Core.BusinessObject /ht:MetaObjects.Models.Core.BusinessObject /im:PublicProtected /pbt:"MetaFramework.NET" /pn:"MetaFramework.NET" /pof:"C:\DOT NET\1.1\MetaObjects\Framework\Help\Reference" /ixml:"C:\DOT NET\1.1\MetaObjects\Framework\Uml\MetaObjects.Framework.Uml.xml"+"C:\DOT NET\1.1\MetaObjects\Framework\MetaObjects.Framework.xml"+"C:\DOT NET\1.1\MetaObjects\Framework\DataAccessLayer\Db\MetaObjects.Framework.DataAccessLayer.Db.xml"+"C:\DOT NET\1.1\MetaObjects\Models\Core\PrimitiveObjects\MetaObjects.Models.Core.PrimitiveObjects.xml"+"C:\DOT NET\1.1\MetaObjects\Models\Core\ComplexObjects\MetaObjects.Models.Core.ComplexObjects.xml"+"C:\DOT NET\1.1\MetaObjects\Framework\Design\MetaObjects.Framework.Design.dll" /tbc:"MetaFramework.NET" /ihm:All /thpbuild /compile
If I then open MetaFramework.NET.thp I get the problems described.
To help reproduce the problem it is possible to sent the projectfile (thp), assemblies and xml files through email.
With kind regards,
Post by Christopher » Tue May 25, 2004 11:29 am
Hi Robert,
I've been able to reproduce this problem here which occurs when running TeeGofer from the Command Line and have included a fix to v2.0.5.5 which will be released shortly.
If you would like an interim build with this fix in please let me know.
Thank you!
Locked
