Same project in recently used projects
TeeGofer general
Locked
Robert van Poelgeest
Post by Robert van Poelgeest » Tue May 18, 2004 3:07 pm
Hi Chris,
I get the same project under File - Recent projects in TeeGofer.exe , the only difference between the two is casing used in the path so both entries actually point to the same underlying project.
With kind regards,
Last edited by Robert van Poelgeest on Mon May 24, 2004 9:02 am, edited 1 time in total.
Post by Christopher » Fri May 21, 2004 6:49 am
Hi Robert,
Can you please tell me the steps you took to reproduce this one?
Many thanks!
Thank you!
http://groups.google.com
http://codenewsfast.com/
Post by Robert van Poelgeest » Mon May 24, 2004 8:59 am
What you can do is save the project for instance in c:\test\testproject.thp and then rename the directory test into TEST and reopen testproject.thp you will see that the project is in there twice. I can't remember how I got the problem the first time around.
With kind regards,
Post by Christopher » Tue May 25, 2004 12:05 pm
Hi Robert,
I've now been able to reproduce this one and have included a fix to it in TeeGofer v2.0.5.5 due out shortly.
Thank you!
Post by Robert van Poelgeest » Mon Jun 14, 2004 11:55 am
Hi Chris,
Is there any news on the v2.0.5.5 release yet?
With kind regards,
Post by Christopher » Tue Jun 15, 2004 1:17 pm
Hi Robert,
Well, the code is ready for release, I just need to build the installer. With any luck I should be able to do this before the end of this week.
Thank you!
Locked
