No comments for Inherited members
TeeGofer general
Locked
Robert van Poelgeest
Post by Robert van Poelgeest » Tue May 18, 2004 2:40 pm
If i look at all members for a class member inherited from the .Net framework display differently as members inherited from my own classes.
For instance:
Equals (inherited from Object)
See System.Object
but an inherited member from a class in the same assembly like:
CreateRows (inherited from BusinessObject)
Gives no information!
MetaObjects
Refresh fixes the problem
Post by Robert van Poelgeest » Tue May 18, 2004 2:53 pm
I noted that Edit - Refresh fixes the problem. Since we are normally building from the command-line I wonder if we need to actually build twice to get the correct inherited members?
With kind regards,
Post by Christopher » Thu May 20, 2004 1:11 pm
Hi Robert,
For instance:
See System.Object
There is an example of this functionality shipped with TeeGofer. Open the SteemaSimpleControl solution under:
C:\Program Files\Steema Software\TeeGofer v2\Examples\SteemaSimpleControlSolution
In the file SimpleControl.cs uncomment the BaseSimpleControlClass and InheritedSimpleControlClass and rebuild the solution.
Now create a new TeeGofer Project using the SteemaSimpleControl.dll making sure that in Project Options you set InheritedMembers to All.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Locked
