Index out of range when removing an assembly
TeeGofer general
Locked
Robert van Poelgeest
Post by Robert van Poelgeest » Tue May 18, 2004 2:18 pm
I am using version 2.5.0.4 and run into the following problem, when i try to remove an assembly from a project it first asks me if i want to continue and if i choose yes if i want to refresh all element information. If I choose yes again i get the following index out of range exception:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at TeeGofer.MetaViewerForm.SaveExistingNodeInfo(Hashtable tmpNodeObjHashTable, Int32 Count)
at TeeGofer.MetaViewerForm.RefreshProjectContents()
at TeeGofer.MetaViewerForm.RefreshProject()
at TeeGofer.MetaViewerForm.RemoveAssemblyRoot()
at TeeGofer.MetaViewerForm.menuItem72_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
TeeGofer
Assembly Version: 2.5.0.4
Win32 Version: 2.5.0.4
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/TeeGofer.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/AxInterop.SHDocVw.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
Interop.SHDocVw
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.MSHelpServices
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeGofer%20v2/Interop.MSHelpServices.DLL
CustomMarshalers
CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
With kind regards,
Post by Christopher » Thu May 20, 2004 12:27 pm
Hi Robert,
I'm having problems reproducing this one here. Using copies of System.Drawing.Design.dll (+.xml) and System.Drawing.dll (+.xml), the steps I take are:
1. File -> New
2. Select System.Drawing.dll
3. File -> Add Assembly...
4. Select System.Drawing.Design.dll
5. File -> Save Project
6. File -> Remove Assembly
7. Select Yes to refresh
This process completes as expected. Does this work OK at your end? Could you step me through your process so I can reproduce this problem here?
Thank you!
http://groups.google.com
http://codenewsfast.com/
Locked
