2.503 Features and bugs?
TeeGofer general
Locked
El Maco
Post by El Maco » Fri Dec 12, 2003 1:56 pm
Played around a bit with 2503 and perhaps encountered some issues?
Created a new empty project. When first dll was added, treeview was still empty, couldn't see anything in view until I had added second assembly.
When adding an assembly with depencies, application crashes if dependency is not in the same directory. Would be nice to
point it out if not found instead of crashing.
Seems like it isn't possible to save project or import/export/save as etc until the project file has been created?
In that case, these menu options should be disabled until they are available. Feels strange to click the "save as" option
and absolutely nothing happens.
Post by Marc » Wed Dec 24, 2003 9:19 am
Re.
This needs a Project refresh to make visible the first assembly. We'll take a look at that. Otherwise best to start a new project with 'Project : New' when there is no intention to start with Custom Nodes.
Re.
Hmmm... In v25023 this should prompt you to search for the assemblies.
ie.
Referenced Assembly not found
TeeGofer is unable to automatically resolve the referenced Assembly:
MyAssembly.MyNamespace.MyClass, Version=3.1.1389.28297, Culture=neutral, PublicKeyToken=null
Do you wish to select the Assembly file manually?
OK Cancel
I've checked that here, seems ok but we'll take a closer look. If you have any info or example to help us reproduce it please let us know.
Re.
Ok, We'll modify that.
Locked
