Propability plots
Ideas and wishes for TeeChart
Propability plots
Post by » Thu Nov 20, 2003 8:53 am
I need propability plots to show a normal distribution or a weibull distribution and so on.
Greetings Heinz
Marjan
Post by Marjan » Mon Nov 24, 2003 5:46 pm
Hi, Heinz.
Using the latest TeeChart version which supports custom axis labels (text and position for individual labels) implementing any non-linear plot should be easy. All you need is transformation for values and labels.
I've implemented it for normal, Weibull and Q-Q plots. I'll prepare an article about this shortly and post it here.
epidata
qq plots etc
Post by epidata » Tue Oct 19, 2004 6:13 pm
When is shortly (mentioned in 2003 november ) ? :( :( :(
Marjan
Post by Marjan » Thu Aug 17, 2006 7:05 pm
Hi.
Sorry about (long) delay. I've implemented some of the probabilities plots (among other addditional statistical charts) for another statistical library I'm working on. Some images are available at http://www.dewresearch.com/StatsSeriesGallery.html. In case you're interested I can send you full C# sources (for TeeChart .NET).
Marjan Slatinek,
epidata
probability plots with teechart
Post by epidata » Tue Feb 27, 2007 9:00 pm
I have now implemented probability plots in EpiData using a standard point series of teechart. The sequence is:
1. create a series with cumulative percentages
.. xvalues cumpercentage
2. convert to probabilities, e.g. see
.. xvalues cumprob
Bland M: Introduction to Medical Statistics. Oxford, 2nd ed. p 112.
3. find an inverse normal function for the probabilites
yvalue = inverse normal (cumprob)
(search internet for "normal probability .....source code", you will get several hits., e.g. "normal probability pascal source"
4. create a standard TChart with a pointseries and do a addxy(xvalues yvalue) and you have the normal probability plot
For a test users can download an application at:
http://www.epidata.dk - general download page later or currently: http://www.epidata.dk/testing.php
example: Image
FrancisP
Post by FrancisP » Mon Oct 01, 2007 1:48 pm
Marjan wrote:Hi.
Marjan,
I would be very interested in the QQ-plot code. Would you be able to send me a copy?
Cheers
Francis
Post by Narcís » Tue Oct 02, 2007 11:13 am
Hi Francis,
Marjan told me that he uses some specialized code to calculate each point Q-Q value so it's a bit difficult to split it into a simple unit. But basically he's using the same approach other customer reported (epidata). He's doing normal probability plot, but if you omit the normalcdf calculation on y values, you'll end up with Q-Q chart.
