Point series tool: grouping points based on proximity
Posted: Thu Nov 06, 2014 2:34 pm
by 16570105
Not sure how to make this or even if something similar is already present but I would love a tool that would allow me to group points in point series based on how close they are. If they are x pixels apart then they should be replaced with different point/symbol indicating how many points are being grouped there until the chart is zoomed enough that they would show normaly.
Re: Point series tool: grouping points based on proximity
Posted: Fri Nov 07, 2014 8:08 am
by narcis
Hi MSR,
Thanks for your suggestion. Which TeeChart version are you using? Knowing the environment you work with we might be able to help you achieve that.
Posted: Fri Nov 07, 2014 10:53 pm
by 16570105
Hello NarcĂ­s,
Thank you for your help. I am using TeeChart Pro v2014 VCL / VCL.NET with 100% Source Code in Delphi XE7.
Posted: Tue Nov 11, 2014 9:38 am
http://bugs.teechart.net/show_bug.cgi?id=996
I've implemented what could be a point to start with.
Take a look at the attached project.
testAbsorbingPoints.zip
(2.32 KiB) Downloaded 3446 times
