RealBasic Xojo
Ideas and wishes for TeeChart
SN74AC00
RealBasic Xojo
Post by SN74AC00 » Thu Jul 18, 2013 10:57 am
Has anyone used Teechart in RealBasic (now called Xojo). If so how?
Roger
Re: RealBasic Xojo
Post by Narcís » Thu Jul 18, 2013 11:11 am
Hi Roger,
I'm sorry but we don't have experience with RealBasic/Xojo. It looks like Xojo supports COM components. That being the case you could use TeeChart ActiveX on it in a similar way you'd do with Visual C++ projects probably. My recommendation would be to download the fully functional TeeChart ActiveX evaluation version and check out the Visual C++ example projects. If Xojo supports other TeeChart supported frameworks (VCL/Firemonkey, .NET/Mono, Java, PHP, HTML5, etc.) then you might give it a go with the corresponding TeeChart version as well.
