TeeChart Export Settings
Ideas and wishes for TeeChart
ramdevteam
Post by ramdevteam » Thu Aug 27, 2009 7:36 am
Currently, the only way for importing/exporting Datas AND chart settings and series setting is to use the .tee binary format.
It's impossible to have this function in XML. Only data can be import.
Best Regards
Re: TeeChart Export Settings
Post by Yeray » Thu Aug 27, 2009 10:06 am
Hi ramdevteam,
You can export your chart and data to xml:
uses teestore;
SaveChartToXMLFile(Chart1, 'C:\tmp\test.xml');
But you can only import your data, not the chart properties, from xml as explained at the Tutorial 15 - XML Export & Import
I've added this to the wish list to be considered for inclusion in future releases (TV52014369).
