Unable to view points in Chart Editor
Mike Jones
Post by Mike Jones » Fri May 15, 2009 8:30 pm
When a series is bound to a datatable, why can't the points be viewed in the Chart Editor.
For example: I modified the TeeChart Examples project by adding a double click event handler to handle a double click on the chart control for the example at Welcome !\Datasets\Data table XY Series. So when I double clicked on the chart that was created in this example, the chart editor is launched and I can use it to inspect the settings on the chart. I then go to the Data Tab but there is not data in there.
Seems like the data should be visible because the chart had to chart with the data in the datatable. I do notice that I can export the data using the Export Tab,.
Am I missing something or is this a limitation?
Post by Sandra » Mon May 18, 2009 8:32 am
Hello Mike Jones,
I could see that there isn't data in Data tab and I have added your request to the wish-list to be considered for inclusion in future releases.
