How can I find the location and size of an axis title?
Mike Jones
Post by Mike Jones » Tue Aug 19, 2008 9:29 pm
I am wanting to place a combobox over the Axis title of the bottom axis of a simple 2D, X-Y chart. I can easily create the combobox, but locating the combobox over the bottom axis title location, has proven to be difficult because the Axis.Title member does not seem to update Left and Top properties.
Is there a way I can get access that that information? I have the source code so if needed I could modify our version of the source to meet our needs.
Post by Pep » Wed Aug 20, 2008 11:36 am
Hello Mike,
you can know where the bottom axis title is placed using :
      String text = "XXXXXXX";
      int twidth = (int) tChart1.Graphics3D.TextWidth(text) / 2;
      int xpos = tChart1.Axes.Bottom.IStartPos + (tChart1.Axes.Bottom.IAxisSize / 2) - twidth;
      int ypos = tChart1.Axes.Bottom.Position + tChart1.Axes.Bottom.Labels.Height + tChart1.Axes.Bottom.Ticks.Length +
           tChart1.Axes.Bottom.AxisPen.Width;
      tChart1.Graphics3D.TextOut(xpos, ypos, text);
Mike Jones
That works!!!
Post by Mike Jones » Wed Aug 20, 2008 3:32 pm
That worked perfectly. Thanks!
Mike Jones
Almost perfect
Post by Mike Jones » Tue Dec 30, 2008 8:16 pm
I have a small problem. When the Chart is resized the position of my combobox is sometimes off and othertimes it is perfect.
i have a method called SetLocation() where I use the code you suggested to set the position of my combobox. I then have tried various events to call the SetLocation method.
I have tried tchart.Layout, tchart.Resize
Both of these events seem to fire inconsistently or the axis label reports bad position values. About half the time the combobox will not move after I have done something to resize the chart.
Is there another event that would work more consistently?
Is it possible to put an event on the Axis label itself ( I could modify my copy of the source to do this)?
Post by Pep » Fri Jan 02, 2009 3:10 pm
Hi Mike,
have you tried to use the OnAfterDraw event ?
About the axis labels, you have the OnGetAxisLabel event which allows to modify the axis labels before to draw, each time that have to be displayed.
