How to allow a user to enter a value
Mike Jones
Post by Mike Jones » Thu May 29, 2008 11:51 pm
I like the DragPoint tool on the chart, but I have a need where I want to give the user the option to right click or double click on a point of a series and a text box appears above the point and allows the user to enter a value in instead of dragging the point.
I can capture a double click on the chart but it is associated with the chart location and not a point. It would be most convenient if the point I could drag would have a MouseDoubleClick event I could subscribe to it.
I do have the source, maybe you could suggest some code I could add to the source that would implement this?
Post by Narcís » Fri May 30, 2008 9:14 am
Hi Mike,
You can easily achieve what you request using code below. You should replace the constant values I'm adding for the text boxes values.
			InitializeChart();
			Steema.TeeChart.Styles.Points points1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
			points1.FillSampleValues();
			Steema.TeeChart.Tools.DragPoint dragPoint1 = new Steema.TeeChart.Tools.DragPoint(tChart1.Chart);
			dragPoint1.Series = points1;
			tChart1.DoubleClick += new EventHandler(tChart1_DoubleClick);
			tChart1.MouseDown += new MouseEventHandler(tChart1_MouseDown);
		private int SeriesIndex = -1;
		private int ValueIndex = -1;
		void tChart1_MouseDown(object sender, MouseEventArgs e)
			for (int i = 0; i < tChart1.Series.Count; i++)
				ValueIndex = tChart1[i].Clicked(e.X, e.Y);
				if (ValueIndex != -1)
					SeriesIndex = i;
					break;
		void tChart1_DoubleClick(object sender, EventArgs e)
			if (SeriesIndex != -1)
				tChart1[SeriesIndex].XValues[ValueIndex] = 5;
				tChart1[SeriesIndex].YValues[ValueIndex] = 5;
				tChart1[SeriesIndex].Repaint();
			SeriesIndex = -1;
			ValueIndex = -1;
Hope this helps!
