Gantt chart & MarksTip?
dave
Post by dave » Fri May 11, 2007 6:58 am
Can MarksTip work with Gantt chart? I've tried but can't seem to work. If not, is there anyway I could have a mouseover on the Gantt Chart to show the description (Y-axis value)?
Edu
Post by Edu » Fri May 11, 2007 10:14 am
Hi Dave
Yes, MarksTips works with Gantt Series, but only works in the Z=0 plane, 3D support for MarkTips tool is not implemented. This is most likely to existing difficulties converting 2D coordinates to 3D coordinates.
Edu
Steema Support Central
http://support.steema.com/
dave
Post by dave » Mon May 14, 2007 12:05 am
Thanks Edu. I tried using the ClickSeries event, but it doesn't work properly for 3D gantt charts (it'll only work if I click on the small rectangle section of the series). I guess this is due to the same reason as MarkTips not working in 3D series?
Edu
Post by Edu » Mon May 14, 2007 8:09 am
Hi Dave
Yes, ClickSeries event doesn't work for the same reason.
Edu
