.NET2 plotting vertical line on datetime series
dave
Post by dave » Wed Apr 18, 2007 7:47 am
I would some advice to plot a vertical line on a datetime line series to indicate the current datetime. So this line will cut across the x-axis (the datetime axis) at where the current date is.
I'm using C# btw.
Edu
Post by Edu » Wed Apr 18, 2007 9:36 am
Hi Dave
You have two possibilities to draw this. The first and easier is using a "ColorLine" Tool, can be something similar as below code:
        private ColorLine colorLine1;
            colorLine1 = new ColorLine(tChart1.Chart);
            colorLine1.Active = true;
            colorLine1.AllowDrag = true;
            colorLine1.Axis = tChart1.Axes.Bottom;
            colorLine1.AllowDrag = false; //If you want that user can't move the ColorLine
            line1.Add(DateTime.Parse("16/04/2007"), 4);
            line1.Add(DateTime.Parse("17/04/2007"), 3);
            line1.Add(DateTime.Parse("18/04/2007"), 7);
            line1.Add(DateTime.Parse("19/04/2007"), 8);
            line1.Add(DateTime.Parse("20/04/2007"), 5);
            line1.Add(DateTime.Parse("21/04/2007"), 2);
            colorLine1.Value = DateTime.Today.ToOADate();
The second possibility, is to draw a line on the canvas of chart. You should do it in the "AfterDraw" event as below code:
private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            Point s = new Point(line1.CalcXPosValue(DateTime.Today.ToOADate()), tChart1.Axes.Left.IStartPos - 10);
            Point e = new Point(line1.CalcXPosValue(DateTime.Today.ToOADate()), tChart1.Axes.Bottom.Position + 10);
            g.Line(s, e);
Edu
Steema Support Central
http://support.steema.com/
dave
Post by dave » Thu Apr 19, 2007 2:46 am
Thanks Edu, I managed to get it to work. I decided to go with the ColorLine option.
BTW, is it possible to display the x-axis value that the ColorLine intersects? I am considering allowing users to drag the line and it'll display the datetime that the line intersects.
Edu
Post by Edu » Thu Apr 19, 2007 8:11 am
Hi Dave
You can use the "DragLine" ColorLine event to do it, as below code:
 colorLine1.DragLine += new EventHandler(colorLine1_DragLine);
        void colorLine1_DragLine(object sender, EventArgs e)
            tChart1.Header.Text = "Date: " + DateTime.FromOADate(colorLine1.Value).ToString();
Edu
dave
Post by dave » Mon Apr 23, 2007 5:21 am
Thanks Edu.
dave
Post by dave » Wed May 09, 2007 6:21 am
Hi Edu,
I notice that when I use ColorLine, the line could be plotted outside the vertical axis. For example, when I set have
but the vertical axis contains date before the colorLine1.Value date, the line is plotted on the right hand side of the right vertical axis. Is there a way I can limit ColorLine to only show up within the period in the horizontal axis?
Edu
Post by Edu » Wed May 09, 2007 10:09 am
Hi Dave
ColorLine has got the "NoLimitDrag" property, if you put it to true, the ColorLine can be draw out of axis range. Also can be interesting to you, to hide the ColorLine when is out of range. You can do something similar as below code:
            colorLine1.NoLimitDrag = true;
        //Below code, hide the tool when is out of range
        private void tChart1_Scroll_1(object sender, EventArgs e)
            for (int i = 0; i < tChart1.Tools.Count; i++)
                if (tChart1.Tools[i] is Steema.TeeChart.Tools.ColorLine) SetActiveColorLine(i);
        private void SetActiveColorLine(int i)
            Steema.TeeChart.Tools.ColorLine tmpColorLine = (Steema.TeeChart.Tools.ColorLine)tChart1.Tools[i];
            if ((tmpColorLine.Value > tmpColorLine.Axis.Maximum) || (tmpColorLine.Value < tmpColorLine.Axis.Minimum))
                tmpColorLine.Active = false;
                tmpColorLine.Active = true;
Other possibility can be disables the tool, when is out of range:
colorLine1.Active = false;
Edu
dave
Post by dave » Wed May 09, 2007 11:27 pm
Thanks Edu, I checked it against Axis.MaxXValue & Axis.MinXValue and it works.
Cheers!
