[WPF] How to set TeeChart.licenses file for a plugin assembly
Posted: Tue Aug 27, 2019 1:08 pm
by 15685386
I use steema.teechart.net.4.2019.8.8 for WPF development. I need to specify a license in a non-exe assembly (A) which uses Steema.TeeChart.WPF.TChart control because I don't have an access to executing assembly (B). To do that I:
  • added TeeChart.licenses file as embedded resource to assembly A project.
  • added a "plugin-constructor" call "new TChart(this)" before creation of any other TChart controls (where "this" is an instance of a type from assembly A).
But this didn't work, I still see "This is an EVALUATION version ..." during runtime; while designtime everything is fine.
Can you please advise how to specify TeeChart.licenses not for an executing assembly, but for assembly actually using TChart?
Re: [WPF] How to set TeeChart.licenses file for a plugin assembly
Posted: Tue Aug 27, 2019 3:36 pm
by Christopher
Have you tried adding the EntryAssembly attribute to the AssemblyInfo of your non-exe assembly (A)? The gif here shows you how to do this (in the context of an ASP.NET app).
Posted: Tue Aug 27, 2019 3:51 pm
by 15685386
Doesn't help. Not sure how could it help though. It is used just to call Assembly.GetEntryAssembly (for WPF-app case) which returns starting-app assembly. Or am I missing something?
I need to embed license not in a starting app assembly, but in dependency assembly which actually uses TChart.
Posted: Wed Aug 28, 2019 7:47 am
by Christopher
Even if you don't have access to the executing assembly, if you drop the TeeChart.licenses file into the same directory as the executable and the two class libraries (your wrapper class library and TeeChart) then the Chart will appear without a watermark.
Posted: Wed Aug 28, 2019 4:41 pm
by 15685386
I am aware of that. But discovering pure license file in output dir looks a bit too much. Also it means that any 3rd party assembly in app dir can use TChart without own license.
1. Do I understand correctly that plugin-constructors are not supported in Steema.TeeChart.WPF?
2. Do I understand correctly that there are no plans to implement plugin-constructors (or other similar functionality) for Steema.TeeChart.WPF?
3. Do I understand correctly that distributing pure copies of TeeChart.License file with the app is a workaround recommended by Steema for cases like mine?
Posted: Thu Aug 29, 2019 3:04 pm
by Christopher
Our concern is that our class library could be wrapped in another class library with full licencing - and so without a watermark - only to be resold. This would be in clear violation of our license agreement.
It is for this reason that the only publically available option, in the very exceptional case that a client does not have access to the executing assembly, is copying a valid TeeChart.licenses file into the directory from which it is executed.
If you feel you have a valid business reason why you don't have access to the executing assembly and at the same time want to embed the TeeChart.license into a wrapper class library, could you please expose this reasoning in an email to sales@steema.com, at which stage our business and legal managers will decide your case.
Posted: Thu Aug 29, 2019 3:34 pm
by 15685386
OK, thank you Christopher. From your message I assume that "yes" is the answer for all 3 of my questions.
So plugin-scenario is not supported by TeeChart anymore.
For further readers there is also a compromise option to create "steema.resources" resource-file at starting assembly location and put there a resource named "TeeChart" containing the license. Though it definitely not plugin-usage scenario.
Posted: Thu Aug 29, 2019 3:46 pm
by Christopher
There is indeed the possibility of wrapping the TeeChart.licenses file in a resources file which has to be named 'steema.resources' and dropping this into the starting assembly location. Of course this does not circumvent the problem you identified of license reuse.
Just to be clear - if you wish to embed both the TeeChart.licenses file and the TeeChart.WPF.dll in a class library produced by your company, please write to sales@steema.com and our business and legal managers will attend to your request.
