FirstVisibleIndex and LastVisibleIndex while zooming
bairog
Re: FirstVisibleIndex and LastVisibleIndex while zooming
Post by bairog » Tue Aug 13, 2019 5:31 am
Christopher wrote:
Mon Aug 12, 2019 11:41 am
Try setting the Labels separation to zero, e.g.
Up to 60 points it's working:
But for example for 70 points (when labels start to overlap each other) - chart itself performs labels thinning (my function Bottom_GetAxisDrawLabel is disabled here):
Post by Christopher » Tue Aug 13, 2019 7:58 am
okay, well, another variation on an earlier technique seems to work in these circumstances, i.e.
        //max visible labels
        private const Int32 maxDisplayedLabelsForBottomaAxis = 20;
        List<string> _labels = new List<string>();
        int _count;
            var rnd = new Random();
            tChart1.Zoomed += TChart1_Zoomed;
            tChart1.UndoneZoom += TChart1_UndoneZoom;
            _count = 4000;
            for (int i = 0; i < _count; i++)
                line1.Add(i, rnd.Next(5));
                _labels.Add($"Point NoClue #{rnd.Next()}");
                if (ShouldDrawIndex(i, 0, _count))
                    tChart1.Axes.Bottom.Labels.Items.Add(i, _labels[i]);
        private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            this.Text = $"Number of labels = {tChart1.Axes.Bottom.Labels.Items.Count}";
        private void TChart1_UndoneZoom(object sender, EventArgs e)
            tChart1.Axes.Bottom.Labels.Items.Clear();
        private bool ShouldDrawIndex(int index, int firstVisible, int lastVisible)
            if ((lastVisible - firstVisible) > maxDisplayedLabelsForBottomaAxis)
                var drawEvery = ((lastVisible - 1 - firstVisible) / maxDisplayedLabelsForBottomaAxis) + 1;
                return index % drawEvery == 0;
            return true;
        private void TChart1_Zoomed(object sender, EventArgs e)
            var xvalues = line1.XValues.Value.Where((x, i) => i < _count);
            var min = line1.XValues.IndexOf(xvalues.Where(x => x >= tChart1.Axes.Bottom.Minimum).First());
            var max = line1.XValues.IndexOf(xvalues.Where(x => x <= tChart1.Axes.Bottom.Maximum).Last());
            for (int i = min; i <= max; i++)
                if(ShouldDrawIndex(i, min, max))
bairog
Post by bairog » Tue Aug 13, 2019 10:07 am
So we've finally returned to using Zoomed and UndoneZoom events :) Looks like it's working now, many thanks.
P. S. As I can see this code is in fact manually calculating FirstVisibleIndex and LastVisibleIndex. First time i was surprised by line:
As I expected line1.XValues.Value to have exactly _count items.
Could you explain please, why that collection has more items despite of the fact that I've added _count points?
Post by Christopher » Tue Aug 13, 2019 10:38 am
You're welcome.
The Value field is public but is for internal use. If you are uncomfortable using it, you can use the more standard API calls:
            List<double> xvalues = new List<double>();
                xvalues.Add(line1.XValues[i]);
            //var xvalues = line1.XValues.Value.Where((x, i) => i < _count);
