Custom Y-Axis Position
LebbingUser
Post by LebbingUser » Mon Jul 15, 2019 6:48 am
Hello Steema Support,
I've got an problem that I don't know how to solve.
Every Line in my Chart got an own Custom Y-Axis, but the first one uses the main Y-Axis.
I implemented a Function that hide or fade in the selected Axis.
But when a Custom Y-Axis is faded in, it doesn't get the same position like the main Axis.
So is there an option to set the same Axis-Position for the Custom Axis as for the main Axis?
Thank you for your help!!
Best regards,
Florian
Custom-Axis is too far left
Re: Custom Y-Axis Position
Post by Christopher » Mon Jul 15, 2019 7:32 am
Hello Florian,
You will need to specify a value for the LeftMargin of the Panel class to shift the Custom Axis across, e.g.
            var line = new Line(tChart1.Chart);
            line.FillSampleValues();
        bool _flag = false;
        Axis _custom = null;
        void SetCustom()
            _flag = !_flag;
            if (_flag)
                tChart1[0].CustomVertAxis = _custom;
                tChart1.Panel.MarginLeft = 7;
                tChart1[0].CustomVertAxis = null;
                tChart1.Panel.MarginLeft = 3;
            _custom = new Axis(tChart1.Chart);
            tChart1.Axes.Custom.Add(_custom);
            SetCustom();
LebbingUser
Post by LebbingUser » Mon Jul 15, 2019 7:34 am
Hello Christopher,
Thanks for your fast help!
But is it possible to post the code in VB.NET?
Thank you very much!
Best regards,
Florian
Post by Christopher » Mon Jul 15, 2019 7:52 am
Hello Florian,
I hope you find this more helpful:
    Private Sub InitializeChart()
        Dim line = New Line(tChart1.Chart)
    Private _flag As Boolean = False
    Private _custom As Axis = Nothing
    Private Sub SetCustom()
        _flag = Not _flag
        If _flag Then
            tChart1(0).CustomVertAxis = _custom
        Else
            tChart1(0).CustomVertAxis = Nothing
        End If
    Private Sub button2_Click(ByVal sender As Object, ByVal e As EventArgs)
        _custom = New Axis(tChart1.Chart)
        SetCustom()
LebbingUser
Post by LebbingUser » Mon Jul 15, 2019 8:23 am
Hello Christopher,
thanks, that works great!
But I've got another question:
How can I change the color of the numbers in the y-axis?
Thanks in advance!
Best regards,
Florian
LebbingUser
Post by LebbingUser » Mon Jul 15, 2019 8:56 am
I've got it already!
It is:
TChart1.Axes.Left.Labels.Font.Color = Color.Red
Thanks for helping!
Best regards,
Florian
