TeeChart Pro Cursor
LebbingUser
TeeChart Pro Cursor
Post by LebbingUser » Thu Apr 18, 2019 12:41 pm
Hi Team,
I've got a question regarding the cursor Tool:
Is it possible to snap between x-values and get the y-value of every series in the chart?
For example:
- there are 3 line-series in the Chart and you add 1 cursor
- these 3 line-series got the same X-values but different Y-values
- now you want to jump along the X-values and mark the assigned Y-value of each line-series
- so with 3 line-series we would have 1 cursor and 3 marks on it
Thank you in advance!
Best regards,
Florian
Re: TeeChart Pro Cursor
Post by Christopher » Tue Apr 23, 2019 7:26 am
first, many apologies for the lateness of this reply.
To answer your question: yes, I think this should be possible, and I attach a code example which does most of what you ask.
        Line _line1 = new Line(), _line2 = new Line(), _line3 = new Line();
        CursorTool _cursorTool = new CursorTool();
            void _cursorTool_SnapChange(object sender, CursorChangeEventArgs e)
              if(e.SnapPoint > -1)
                    var values = "Line1 YValue: " + _line1.YValues[e.SnapPoint] + Environment.NewLine;
                    values += "Line2 YValue: " + _line2.YValues[e.SnapPoint] + Environment.NewLine;
                    values += "Line3 YValue: " + _line3.YValues[e.SnapPoint] + Environment.NewLine;
                    tChart1.Header.Text = values;
            tChart1.Series.Add(_line1).FillSampleValues();
            tChart1.Series.Add(_line2).FillSampleValues();
            tChart1.Series.Add(_line3).FillSampleValues();
            tChart1.Tools.Add(_cursorTool);
            _cursorTool.Series = _line1;
            _cursorTool.Style = CursorToolStyles.Vertical;
            _cursorTool.Snap = true;
            _cursorTool.SnapChange += _cursorTool_SnapChange;
            _cursorTool.FollowMouse = true;
LebbingUser
Post by LebbingUser » Wed Apr 24, 2019 2:07 pm
Hi Christopher,
thank you for your help, but is it maybe possible to post the code in VB.NET again?
Thanks a lot!
Post by Christopher » Thu Apr 25, 2019 6:40 am
Of course, here you are:
    Private _line1 As Line = New Line(), _line2 As Line = New Line(), _line3 As Line = New Line()
    Private _cursorTool As CursorTool = New CursorTool()
    Private Sub InitializeChart()
        TChart1.Series.Add(_line1).FillSampleValues()
        TChart1.Series.Add(_line2).FillSampleValues()
        TChart1.Series.Add(_line3).FillSampleValues()
        TChart1.Tools.Add(_cursorTool)
        _cursorTool.Snap = True
        AddHandler _cursorTool.SnapChange, AddressOf _cursorTool_SnapChange
        _cursorTool.FollowMouse = True
    Private Sub _cursorTool_SnapChange(ByVal sender As Object, ByVal e As CursorChangeEventArgs)
        If e.SnapPoint > -1 Then
            Dim values = "Line1 YValue: " & _line1.YValues(e.SnapPoint).ToString() + Environment.NewLine
            values += "Line2 YValue: " & _line2.YValues(e.SnapPoint).ToString() + Environment.NewLine
            values += "Line3 YValue: " & _line3.YValues(e.SnapPoint).ToString() + Environment.NewLine
            TChart1.Header.Text = values
        End If
LebbingUser
Post by LebbingUser » Thu Apr 25, 2019 7:36 am
Hi Christopher,
that works fine!
Perfect, thank you very much for your quick help!
Best regards!
