BackgroundImage not saving on Export
Posted: Mon Nov 26, 2018 3:21 pm
by 13050364
Hello everyone
It appears if you set the BackgroundImage from code then this background image is not saved when you do "Export.Template.Save(fileName)"
Or at least when I do "Import.Template.Load(fileName)" the BackgroundImage property is set to null.
It works OK if I set the BackgroundImage from the development environment (ie. not from software)
For info we are using TeeChart version 3.5.3187.15585 and C#.NET with Visual Studio 2015
Is there anything I can do to make this work? Perhaps I'm missing a step somewhere.
Or is there a workaround?
Dave.
Re: BackgroundImage not saving on Export
Posted: Tue Nov 27, 2018 8:58 am
by Christopher
Hello Dave,
the BackgroundImage property is a .NET Framework property belonging to the Control class and as such will not be serialized - there is similar TeeChart property, the Panel.Brush.Image property, the use of which you will find in the attached project.
BackgroundImage.zip
(117.54 KiB) Downloaded 1013 times
Posted: Tue Nov 27, 2018 7:41 pm
by 13050364
Sensational! Thanks Chris
