Adding a Scroll Pager tool throws exception
Posted: Mon Dec 19, 2016 11:49 pm
by 16079247
I've reported a previous bug regarding scroll pager serialization issue (ID1395]
http://bugs.teechart.net/show_bug.cgi?id=1395). Now that it has been fixed and for this I've just have upgraded to the latest build (4.1.2016.10261). I am able to open the previously saved charts with scroll pager but found that the the scroll pager tool is not working.
To reproduce, add a series and then add a scroll pager tool from the tools tab. Index out of range exception thrown.
Can we please get a quick solution to this? I have access to source for any modification required.
Khaled
Re: Adding a Scroll Pager tool throws exception
Posted: Tue Dec 20, 2016 9:33 am
by Christopher
Hello Khaled,
Attached here:
a small project that references the latest public version of TeeChart.dll. When I run this project here, I get the following result:
http://screencast.com/t/RseFtYnOsEL
do you get the same at your end? If not, could you please send me some code with which I can reproduce your problem at this end?
Posted: Tue Dec 20, 2016 12:16 pm
by Christopher
Khaled,
Christopher wrote:do you get the same at your end? If not, could you please send me some code with which I can reproduce your problem at this end?
an update - I can see that there is, in fact, a couple of problems with ScrollPager serialization *at designtime*, one of which has been present for the last two releases and one of which is present in the last release. I am looking at it now and will get back to you when I have resolved the issues.
Posted: Tue Dec 20, 2016 3:25 pm
by Christopher
Christopher wrote:I am looking at it now and will get back to you when I have resolved the issues.
If you have the source code, within the ScrollPager.cs unit you can make these changes:
- change1.PNG (27.65 KiB) Viewed 16902 times
- change2.PNG (29.89 KiB) Viewed 16904 times
these should fix the designtime issues for you.
Posted: Tue Dec 20, 2016 11:14 pm
by 16079247
Hi Chris,
That has resolved the exception, but after the change in code the subchart is not scrollable at all. I can not change the selection/ boundary for the scrollable chart in design mode.
Posted: Thu Dec 22, 2016 1:04 pm
by Christopher
I've made a number of changes to ScrollPager.cs, and although changing the boundaries with the mouse at designtime as one can at runtime is not possible (the boundaries can be changed using the Chart Editor, however), changes at designtime are now more accurately reflected at runtime. Possibly the easiest way to get these changes to you is by email - if you could give me your email I can sent this modified unit to you.
Posted: Tue Jan 03, 2017 12:17 am
by 16079247
My email address is:
khaleds@sentinelpl.com.au
I will be awaiting for your email with the modifications
Posted: Sun Jan 08, 2017 9:38 pm
by 16079247
Still waiting for the email with the modified project
Posted: Mon Jan 09, 2017 2:47 pm
by Christopher
Apologies for the delay - I have now sent you the unit.
Posted: Mon Jan 09, 2017 10:19 pm
by 16079247
Received, thanks
