No chart display at runtime after chart created at design
ysyeh
Post by ysyeh » Fri Nov 11, 2016 4:02 pm
Environment: Windows 7 - VS2013 - Visual C# - .NET Framework 4.6.1 - Windows Forms Application with TeeChartNET2015_4.1.2015.12160
What I did:
1. Put a TChart component on Form1
2. Add a Bar Series with Data Source specified as 'Random'
The design time screen in IDE shows chart with 6 bars.
When I click 'Start' button on IDE screen, the runtime screen shows a form with blank TeeChart; no bar shows up.
Is this normal? I know if I add codes to initialize the chart I can get the 6 bars shown in runtime screen. But without codes should the 6 bars also show up when bar series is defined at design time only?
Re: No chart display at runtime after chart created at design
Post by Christopher » Mon Nov 14, 2016 8:50 am
ysyeh wrote: Is this normal? I know if I add codes to initialize the chart I can get the 6 bars shown in runtime screen. But without codes should the 6 bars also show up when bar series is defined at design time only?
Yes, this is normal. The reason is that a series at designtime is filled with random data by default, whereas at runtime it is left empty. To see the equivalent random data at runtime, you can add:
bar1.FillSampleValues();
ysyeh
Post by ysyeh » Mon Nov 14, 2016 1:56 pm
Thanks!
