EquiVolume conversion
Quant
Post by Quant » Tue Mar 29, 2016 10:45 am
I am converting existing candle series to EquiVolume and adding volumes from existing volume series.
Conversion is successful but EquiVolume series is not visible when I check data of it volume values are zero values.
My existing candle series and volume series both are having data.
I am using following code
                        Series candleSeries = tChart1.Series[0];
                        Series.ChangeType(ref candleSeries, typeof(Steema.TeeChart.Styles.EquiVolume));
                        EquiVolume eqVol = (EquiVolume)candleSeries;
                        eqVol.VolumeValues = volumeSeries.YValues;
Quant
Re: EquiVolume conversion
Post by Quant » Tue Mar 29, 2016 11:14 am
I didn't find any code related to EquiVolume in TeeChart Samples.
But my problem is solved with
    eqVol.VolumeValues.Value = volumeSeries.YValues.Value;
New problem arises after conversion of series to EquiVolume. Chart Control slows down after conversion of candle to EquiVolume.
Post by Christopher » Wed Mar 30, 2016 12:02 pm
Quant wrote:New problem arises after conversion of series to EquiVolume. Chart Control slows down after conversion of candle to EquiVolume.
Using test code similar to the following:
    TChart tChart1;
      Utils.CalcFramesPerSecond = true;
      tChart1 = new TChart();
      tChart1.Series.Add(typeof(EquiVolume)).FillSampleValues(50);
      timer.Interval = 10;
      timer.Tick += Timer_Tick;
      timer.Start();
    private void Timer_Tick(object sender, EventArgs e)
      tChart1[0].FillSampleValues(50);
      this.Text = Utils.FramesPerSecond.ToString();
no significant difference in FPS can be detected between Candle and EquiVolume series. Can you please send us some code which clearly shows the slowing down you speak of?
