Rotating DrawLineItem Shapes
Quant
Post by Quant » Fri Jan 15, 2016 9:36 am
We want to rotate following DrawLineItem shapes using mouse:
1] Rectangle
2] Horizontal Parallel Line
3] Vertical Parallel Line
I did not find anything in the source files, Do you have any example code for the same?
Re: Rotating DrawLineItem Shapes
Post by Christopher » Tue Jan 19, 2016 10:09 am
Quant wrote:I did not find anything in the source files, Do you have any example code for the same?
A very basic example uses this class:
  public class MyDrawLine : DrawLine
    public MyDrawLine(Chart c) : base(c)
      Brush = new ChartBrush(c);
    public ChartBrush Brush { get; set; }
    protected override void ChartEvent(EventArgs e)
      if (e is AfterDrawEventArgs)
        if (Lines.Count > 0)
          foreach (DrawLineItem l in Lines)
            RedrawBrushLine(l);
        if (drawing)
          RedrawBrushLine(Selected);
      base.ChartEvent(e);
    protected override void MouseEvent(MouseEventKinds kind, MouseEventArgs e, ref Cursor c)
      base.MouseEvent(kind, e, ref c);
      if (kind == MouseEventKinds.Wheel)
        Delta += e.Delta;
        Chart.Invalidate();
    private int Delta;
    private void RedrawBrushLine(DrawLineItem line)
      Graphics3D g = Chart.Graphics3D;
      Graphics gdi = g.GDIplusCanvas;
      g.Brush = Brush;
      if ((Chart != null) && g.ValidState())
        Matrix m = gdi.Transform;
        Rectangle r;
        int x, y;
        PointF p;
        Point tmpP1, tmpP2;
        if (line == null)
          r = new Rectangle(FromPoint, new Size(Math.Abs(ToPoint.X - FromPoint.X), Math.Abs(ToPoint.Y - FromPoint.Y)));
          tmpP1 = AxisPoint(line.StartPos);
          tmpP2 = AxisPoint(line.EndPos);
          r = new Rectangle(tmpP1, new Size(Math.Abs(tmpP1.X - tmpP2.X), Math.Abs(tmpP1.Y - tmpP2.Y)));
        Graphics3D.RectCenter(r, out x, out y);
        p = new PointF(x, y);
        m.RotateAt(Delta, p);
        gdi.MultiplyTransform(m);
        DrawLineStyle s = (line == null) ? this.Style : line.Style;
        bool oldPen = g.Pen.Visible;
        g.Pen.Visible = false;
        ClipDrawingRegion(g);
        if (line == null)
          DoDrawLine(g, this.FromPoint, this.ToPoint, s);
          DoDrawLine(g, AxisPoint(line.StartPos), AxisPoint(line.EndPos), s);
        g.Pen.Visible = oldPen;
        g.UnClip();
        gdi.ResetTransform();
    private void DoDrawLine(Graphics3D g, Point StartPos, Point EndPos, DrawLineStyle AStyle)
      if (!base.Chart.Aspect.View3D)
        if (AStyle != DrawLineStyle.Line)
          if (AStyle == DrawLineStyle.Rectangle)
            g.Rectangle(Utils.FromLTRB(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y));
          else if (AStyle == DrawLineStyle.Ellipse)
            g.Ellipse(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y);
      else if (AStyle != DrawLineStyle.Line)
          g.Rectangle(Utils.FromLTRB(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y), 0);
          g.Ellipse(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y, 0);
And can be consumed like this:
      Line line1 = new Line(tChart1.Chart);
      line1.Add(2, 2);
      line1.Add(8, 8);
      MyDrawLine drawLine1 = new MyDrawLine(tChart1.Chart);
      drawLine1.Pen.Visible = false;
      drawLine1.Brush.Color = Color.Red;
      Steema.TeeChart.Tools.DrawLineItem I = new Steema.TeeChart.Tools.DrawLineItem(drawLine1);
      double tmp = line1.YValues.Range / 5.0;
      I.StartPos = new PointDouble(5, line1.YValues.Maximum - tmp);
      I.EndPos = new PointDouble(7, line1.YValues.Minimum + tmp);
      I.Style = DrawLineStyle.Rectangle;
