Fill Ellipse Tool
Quant
Fill Ellipse Tool
Post by Quant » Sat Jan 09, 2016 5:58 am
We require fill properties (like Fill Color/Pattern, Transparency %, etc.) of Drawline Tool for following shapes:
1] Ellipse
2] Rectangle
3] Horizontal Parallel Line
4] Rectangle Parallel Line
Re: Fill Ellipse Tool
Post by Christopher » Mon Jan 11, 2016 10:47 am
Quant wrote: We require fill properties (like Fill Color/Pattern, Transparency %, etc.) of Drawline Tool for following shapes:
The DrawLine Tool enables a user to draw lines on a TeeChart. Lines only have Pen characteristics, unlike the shapes you mention which have both Pen and Brush characteristics. I'm not sure I understand how you want the DrawLine Tool to draw anything other than lines. Could you please explain?
Quant
Post by Quant » Tue Jan 12, 2016 4:05 am
DrawLine Tool also provides a style property which has options for following shapes:
  • Line,
    HorizParallel,
    VertParallel,
    Rectangle,
    Ellipse
We did check the source code of DrawLine.cs and we knew that it has only Pen Characteristics but we have a requirement where user wants fill properties (like fill color, fill pattern, transparency etc.) for shapes other than Line. It would be of great feature for TeeChart if these shapes have a fill properties because user can use these tools for highlighting specific regions based on their needs. So we would like to request you to consider this requirement. Going further, if you are considering this requirement for future release please provide us some kind of solution to complete this requirement asap.
Post by Christopher » Wed Jan 13, 2016 5:29 pm
Quant wrote:So we would like to request you to consider this requirement. Going further, if you are considering this requirement for future release please provide us some kind of solution to complete this requirement asap.
I have added this request as an enhancement to our issue tracking software with id=1405.
In the meantime, a workaround is relatively straightforward. Firstly, add this class to your code:
  public class MyDrawLine : DrawLine
    public MyDrawLine(Chart c) : base(c)
      Brush = new ChartBrush(c);
    public ChartBrush Brush { get; set; }
    protected override void ChartEvent(EventArgs e)
      if (e is AfterDrawEventArgs)
        if (Lines.Count > 0)
          foreach (DrawLineItem l in Lines)
            RedrawBrushLine(l);
        if (drawing)
          RedrawBrushLine(Selected);
      base.ChartEvent(e);
    private void RedrawBrushLine(DrawLineItem line)
      Graphics3D g = Chart.Graphics3D;
      g.Brush = Brush;
      if ((Chart != null) && g.ValidState())
        DrawLineStyle s = (line == null) ? this.Style : line.Style;
        bool oldPen = g.Pen.Visible;
        g.Pen.Visible = false;
        ClipDrawingRegion(g);
        if (line == null)
          DoDrawLine(g, this.FromPoint, this.ToPoint, s);
          DoDrawLine(g, AxisPoint(line.StartPos), AxisPoint(line.EndPos), s);
        g.Pen.Visible = oldPen;
        g.UnClip();
    private void DoDrawLine(Graphics3D g, Point StartPos, Point EndPos, DrawLineStyle AStyle)
      if (!base.Chart.Aspect.View3D)
        if (AStyle != DrawLineStyle.Line)
          if (AStyle == DrawLineStyle.Rectangle)
            g.Rectangle(Utils.FromLTRB(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y));
          else if (AStyle == DrawLineStyle.Ellipse)
            g.Ellipse(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y);
      else if (AStyle != DrawLineStyle.Line)
          g.Rectangle(Utils.FromLTRB(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y), 0);
          g.Ellipse(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y, 0);
And then consume it in an example like this:
      Line line1 = new Line(tChart1.Chart);
      line1.Add(2, 2);
      line1.Add(8, 8);
      MyDrawLine drawLine1 = new MyDrawLine(tChart1.Chart);
      drawLine1.Pen.Color = Color.Yellow;
      drawLine1.Pen.Width = 2;
      drawLine1.Brush.Color = Color.Red;
      Steema.TeeChart.Tools.DrawLineItem I = new Steema.TeeChart.Tools.DrawLineItem(drawLine1);
      double tmp = line1.YValues.Range / 5.0;
      I.StartPos = new PointDouble(5, line1.YValues.Maximum - tmp);
      I.EndPos = new PointDouble(7, line1.YValues.Minimum + tmp);
      I.Style = DrawLineStyle.Rectangle;
Quant
Post by Quant » Thu Jan 14, 2016 4:04 am
Thanks for the help.
But we already updated DrawLine.cs which works as required. Check the below code snippet :
      bool oldBrush, oldPen;
          if (AStyle == DrawLineStyle.HorizParallel)
            g.HorizontalLine(StartPos.X, EndPos.X, StartPos.Y);
            g.HorizontalLine(StartPos.X, EndPos.X, EndPos.Y);
            if (IsFilled)
                g.Brush.Color = FillColor;
                g.Brush.Transparency = FillTransparency;
                //Add Rectangle with Transparency
          else if (AStyle == DrawLineStyle.Rectangle)
            oldBrush = g.Brush.Visible;
            if (IsFilled)
                g.Brush.Visible = true;
                g.Brush.Visible = false;
            g.Brush.Visible = oldBrush;
            if (IsFilled)
            g.VerticalLine(StartPos.X, StartPos.Y, EndPos.Y);
            g.VerticalLine(EndPos.X, StartPos.Y, EndPos.Y);
            if (IsFilled)
          g.Line(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y);
We also added following additional properties to DrawLine class as :
  • IsFilled
    FillColor
    FillTransparency
Do revert for any suggestion or any code changes related to above code snippet.
