Fibonanci Retracement Tool
Hi All,
There is no event for FibonanciTool (other than Disposed) present in TeeChart .Net.
We need to select already drawn FibonanciTool using code. How can we achieve the same?
- Site Admin
- Contact:
Re: Fibonanci Retracement Tool
Hello Quant,
Yes, you are right. I have added your request to bugzilla (#1174). Does the bug description fit your needs?
Thanks for your collaboration.
i am using latest version 4.1.2015.08061 but still not getting any event.
- Guru
That's because no event was added; however, a Clicked method was added which can be used like this:Quant wrote:i am using latest version 4.1.2015.08061 but still not getting any event.
FibonacciTool tool;
tool = new FibonacciTool(tChart1.Chart);
Candle candle = new Candle(tChart1.Chart);
candle.FillSampleValues(40);
tool.StartX = candle.DateValues[0];
tool.StartY = candle.CloseValues[0];
tool.EndX = candle.DateValues[10];
tool.EndY = candle.CloseValues[10];
tool.Series = candle;
tChart1.MouseDown += TChart1_MouseDown;
private void TChart1_MouseDown(object sender, MouseEventArgs e)
tChart1.Header.Text = "FibonacciTool clicked " + tool.Clicked(e.X, e.Y);
by this way selection can not be highlighted.
I want selector tool to select fibonacci. same as we are selecting rectangle or line.
- Guru
You could highlight the tool by changing the Pen colors, e.g.Quant wrote:by this way selection can not be highlighted.
bool clicked = tool.Clicked(e.X, e.Y);
for (int i = 0; i < tool.Levels.Count; i++)
tool.Levels[i].Pen.Color = clicked ? Color.Fuchsia : Color.Black;
tool.TrendPen.Color = clicked ? Color.Fuchsia : Color.Black;
we dont want this work around. we want same way as we select line or rectangle tool.
- Guru
How do you select a line or a rectangle tool?Quant wrote:we dont want this work around. we want same way as we select line or rectangle tool.
with selector tool
- Guru
I see, thank you. This is quite a different request to the origin request in this thread, and as such has been added to our issue tracking software with id=1325.Quant wrote:with selector tool
Selector marks can be client coded on the Fibonacci Trendline in this way:
The Arcs or alternatively drawstyled lines can also have selector marks applied to them, it requires a little more work to extract the values from the Fibonacci class.
bool isFiboClicked = false;
if (fibonacciTool1.Clicked(e.X, e.Y))
isFiboClicked = true;
tChart1.Invalidate();
private void tChart1_AfterDraw(object sender, Drawing.Graphics3D g)
if (isFiboClicked)
int startX = tChart1.Axes.Bottom.CalcPosValue(fibonacciTool1.StartX);
int startY = tChart1.Axes.Left.CalcPosValue(fibonacciTool1.StartY);
int endX = tChart1.Axes.Bottom.CalcPosValue(fibonacciTool1.EndX);
int endY = tChart1.Axes.Left.CalcPosValue(fibonacciTool1.EndY);
g.Brush.Solid = true;
g.Brush.Color = Color.Black;
g.Rectangle(startX - 4, startY - 4, startX + 4, startY + 4);
g.Rectangle(endX - 4, endY - 4, endX + 4, endY + 4);
