Page 2 of 2
Re: Trendline with Snap to Point & Semi log Aware Trendline
Posted: Thu Sep 03, 2015 11:06 am
by Christopher
Quant wrote: *Line is converted to log curve *
http://www.youtube.com/watch?v=y55VmSIMBjE
for mathematical formula use below link
https://en.wikipedia.org/wiki/Semi-log_plot
Thank you.
Semi-log plots are perfectly feasible in TeeChart, e.g.
    Line series;
      series = new Line(tChart1.Chart);
      series.Add(9, 25112);
      series.Add(12, 12223);
      series.Add(14, 9216);
      series.Add(16, 7488);
      series.Add(21, 4889);
      tChart1.Axes.Left.Logarithmic = true;
      tChart1.Axes.Left.Increment = 5000;
      tChart1.Axes.Left.SetMinMax(2000, 40000);
      tChart1.Axes.Bottom.SetMinMax(5, 25);
Trendlines and other TeeChart functions can also be used in semi-log plots, e.g.
    Line series, func;
      func = new Line(tChart1.Chart);
      TrendFunction trend = new TrendFunction();
      trend.TrendStyle = TrendStyles.Exponential;
      func.Function = trend;
      func.DataSource = series;
of the video you link to, which functionality do you need which is present in Excel but which you cannot find in TeeChart?
Posted: Thu Sep 03, 2015 11:56 am
by 16071129
I am using drawline tool. I cant use series as use is drawing line as per his requirement. how to make semi log lines drawn by drawline
Posted: Thu Sep 03, 2015 1:05 pm
by Christopher
Quant wrote:how to make semi log lines drawn by drawline
I'm sorry, but I don't understand this request. The DrawLine tool is designed to draw a line between two points defined by mouse clicks. This tool works as expected in semi-log charts.
Posted: Wed Sep 09, 2015 4:51 am
by 16071129
1) I am using drawline tool to draw a line on normal scale.
2) when i convert normal scale to semilog
3) all series got converted to semilog except the line drawn with drawline tool.
4) I want to convert this line which is drawn by drawline tool to semilog.
Posted: Wed Sep 09, 2015 10:19 am
by Christopher
Quant wrote:1) I am using drawline tool to draw a line on normal scale.
The following code does all of the above:
    Line series;
    DrawLine tool;
      tool = new DrawLine(tChart1.Chart);
      tChart1.Draw();
      DrawLineItem line = new DrawLineItem(tool);
      line.StartPos = new PointDouble(9, 25112);
      line.EndPos = new PointDouble(21, 4889);
      tool.Lines.Add(line);
Posted: Wed Sep 09, 2015 10:52 am
by 16071129
we dont want predefined series. we want user to draw line same as drawing with drawline tool.
Posted: Wed Sep 09, 2015 1:31 pm
by Christopher
Quant wrote:we dont want predefined series. we want user to draw line same as drawing with drawline tool.
I'm afraid I don't understand what you mean here. Could you please try and be a little more specific with the use of code examples I can run here, images and videos?
Posted: Fri Oct 09, 2015 10:29 am
by Marc
Drawline tool may be used in normal manner. Code values will be updated according to any Axis visualisation changes. DrawLine co-ordinates can be updated at any time by customer code.
Posted: Fri Feb 19, 2016 9:38 am
by 16071129
We are starting this discussion again to discuss "Semi-Log Trendline" in more detail, thereby we can help each other to solve this requirement.
Note: Following steps are based on usage of "Semi-Log Trendline" from a popular charting software.
Step 1] Consider a chart (OHLC with Candle Line) with Right Axis Semi Log Scaled as shown in below screenshot (Screen 1).
Screen 1
Step 2] Now a User Draws a "Semi-Log Trendline" on a Chart by using "Semi-Log Trendline" Tool as shown in below Screenshot (Screeen 2).
As shown in "Screen 2" it shows straight line drawn on semi log scaled chart.
Screen 2
Step 3] When user changes Semi log scale to Arithmetic scale, then previously drawn straight line becomes a curved line as shown in below screenshot (Screen 3).
Screen 3
Above three steps comprises of Semi Log Trendline working.
Posted: Mon Feb 22, 2016 12:05 pm
by Christopher
Quant wrote: Above three steps comprises of Semi Log Trendline working.
Here it is working in TeeChart:
    Line series;
    DrawLine tool;
    private List<PointDouble> CalcCurve()
      List<PointDouble> result = new List<PointDouble>();
      Point start = new Point(tChart1.Axes.Bottom.CalcXPosValue(tool.Lines[0].StartPos.X), tChart1.Axes.Left.CalcYPosValue(tool.Lines[0].StartPos.Y));
      Point end = new Point(tChart1.Axes.Bottom.CalcXPosValue(tool.Lines[0].EndPos.X), tChart1.Axes.Left.CalcYPosValue(tool.Lines[0].EndPos.Y));
      double dxdy = (double)Math.Abs(start.X - end.X) / (double)Math.Abs(start.Y - end.Y);
      int count = 0;
      for (int i = start.Y; i <= end.Y; i++)
        result.Add(new PointDouble(tChart1.Axes.Bottom.CalcPosPoint(start.X + Utils.Round(count * dxdy)), tChart1.Axes.Left.CalcPosPoint(i)));
        count++;
      return result;
      if(tChart1.Axes.Left.Logarithmic)
        List<PointDouble> list = CalcCurve();
        Line newLine = new Line(tChart1.Chart);
        newLine.Color = Color.Black;
        newLine.Legend.Visible = false;
        tChart1.Legend.LegendStyle = LegendStyles.Values;
        foreach (var item in list)
          newLine.Add(item.X, item.Y);
        tool.Active = false;
        if(tChart1.Series.Count > 1)
          tChart1.Series.RemoveAt(1);
        tool.Active = true;
      tChart1.Axes.Left.Logarithmic = !tChart1.Axes.Left.Logarithmic;
Step 1:
Step 2:
This is just a proof of concept that TeeChart is capable of rendering this change from [straight line in log] -> [curve in non-log] ... the actual implementation of this in your context may be a little different.
Posted: Mon Mar 14, 2016 8:43 am
by 16071129
Thanks for the reply. Yes sample code is working as per the same concept.
But how can we draw semi log trend line vice versa i.e. [curve in non-log] --> [straight line in log]. Could you please provide the sample code for the same?
Posted: Mon Mar 14, 2016 9:00 am
by Christopher
Quant wrote:But how can we draw semi log trend line vice versa i.e. [curve in non-log] --> [straight line in log]. Could you please provide the sample code for the same?
Again, I'm not sure about your requirements here, but the code I sent you can be engineered to work in reverse so that it draws the "log curve" in the non-log plot and vice-versa. I'm afraid I don't have the time at the moment to actually write the code for you.
