Exporting to bitmap problems
Petr
Post by Petr » Wed Feb 26, 2014 4:06 pm
Hello, i'm trying to Save a bitmap of chart, i use to export it to .bmp with
public void PrintChart()
m_TChart.Export.Image.Bitmap.Save("preprint.bmp");
I use direct2D as a Graphics. As a result i get only black rectangle. What am i doing wrong, and how can i get the chart bitmap in other way. I also tried to use Bitmap property of TeeChart directly, but the result is the same.
P.S. Generely i wanted to Print chart. I Trid to use Printer.Preview(), but there's a white sheet in a Print Preview dialog. Somethere on the forum i saw a topic about a problems with printing in case of using dierct2D, so may be it's related. Also i'm using the latest version of TeeChart.
Re: Exporting to bitmap problems
Post by Christopher » Wed Feb 26, 2014 4:15 pm
Petr wrote:P.S. Generely i wanted to Print chart. I Trid to use Printer.Preview(), but there's a white sheet in a Print Preview dialog. Somethere on the forum i saw a topic about a problems with printing in case of using dierct2D, so may be it's related. Also i'm using the latest version of TeeChart.
This is a known issue and progress on it can be read in bug ID356.
