Crash at try t move colorline tool with Direct2D
Petr
Post by Petr » Wed Feb 26, 2014 12:46 pm
Hi, i use Direct@d as a graphics3d in TeeCahert. i add coloroline tool to the chart and set allow drag property to true, when i try to drag it appears big red cross on white background. I got some info about it.
************** Exception Text **************
SlimDX.Direct2D.Direct2DException: D2DERR_WRONG_STATE: The object was not in the correct state to process the method. (-2003238911)
at SlimDX.Result.Throw[T](Object dataKey, Object dataValue)
at SlimDX.Result.Record[T](Int32 hr, Boolean failed, Object dataKey, Object dataValue)
at SlimDX.Direct2D.RenderTarget.EndDraw()
at Steema.TeeChart.Drawing.Direct2D.Graphics3DDirect2D.ShowImage(Graphics g)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
So how can it be fixed?
Re: Crash at try t move colorline tool with Direct2D
Post by Christopher » Wed Feb 26, 2014 2:23 pm
Petr wrote:Hi, i use Direct@d as a graphics3d in TeeCahert. i add coloroline tool to the chart and set allow drag property to true, when i try to drag it appears big red cross on white background. I got some info about it.
Thank you for reporting this issue to us, I have added it to our bug tracking software which all clients of Steema are encouraged to use as ID607.
