Rubber band Zoom
asupriya
Rubber band Zoom
Post by asupriya » Sat Aug 10, 2013 6:26 am
Our concern is about the HighlightedGraphPanel.Axes.Bottom.Minimum/Maximum. By default, we have the display unit as 'time' & then we do the zooming with the X-axis for some frame followed by making the change in the display unit from the 'time' to other units e.g. "cycles', "seconds". Our desired zoomed in position get lost with the change in the display unit & traces get into the default position. So, we don't want to loose our desired zoom in effect on changing the display unit that has an out & out relation with the values of HighlightedGraphPanel.Axes.Bottom.Minimum/Maximum
Re: Rubber band Zoom
Post by Sandra » Mon Aug 12, 2013 1:12 pm
Hello asupriya,
Could you please, send us your project because we can try to reproduce your problem here?
