Annotations and y-axis
asupriya
Post by asupriya » Tue Jul 30, 2013 2:08 pm
1. Is it possible to cancel the mouse move option to annotations?
2. Is it possible to change the y-axis setrange() while double_Clicking on the y-axis?
Re: Annotations and y-axis
Post by Sandra » Wed Jul 31, 2013 9:38 am
Hello asupriya,
You can make that in chart nothing is done when the mouse is over in the annotation tool. You can do something as I have made in next example of code in MouseMove event:
 void tChart1_MouseMove(object sender, MouseEventArgs e)
       if (!(an1.Shape.Left< e.X &&  e.X < an1.Shape.Right) )
        if (!(an1.Shape.Top < e.Y && e.Y < an1.Shape.Bottom))
          an1.Text = "Hello";
          tChart1.Header.Text = e.X.ToString() + "," + e.Y.ToString();
In this case you need use in AxisClick Event the SetMinMax() to change the scale of left axis as you want. For example, you can do something as next:
void tChart1_ClickAxis(object sender, MouseEventArgs e)
      tChart1.Axes.Left.SetMinMax(tChart1.Axes.Left.Minimum + 10, tChart1.Axes.Left.Maximum);
Could you tell us if previous codes help you to achieve as you want?
I hope will helps.
