Pie Charts
Posted: Wed Oct 26, 2011 1:57 pm
by 8123522
2 Questions on the pie charge sample attached,
1. how can I add the % symbol next to the figure
My code is:-
pie.Add(Convert.ToInt32(ethnicperc1), "White", Color.FromArgb(49, 151, 101));
pie.Add(Convert.ToInt32(ethnicperc2), "Mixed", Color.FromArgb(255, 255, 255));
pie.Add(Convert.ToInt32(ethnicperc3), "Asian", Color.FromArgb(245, 152, 31));
pie.Add(Convert.ToInt32(ethnicperc4), "Black", Color.FromArgb(205, 205, 205));
pie.Add(Convert.ToInt32(ethnicperc5), "Other" , Color.FromArgb(244, 243, 160));
pie.Add(Convert.ToInt32(ethnicperc6), "Not Answered", Color.FromArgb(157, 197, 233));
pie.Rotate(90);
2. The pie appears to be generated anticlockwise, is there a way of make it clockwise
Re: Pie Charts
Posted: Thu Oct 27, 2011 10:30 am
by 10050769
Hello MikeTheLad,
You need use property Style of Marks as do in next simple code:
            Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
            tChart1.Legend.Visible = true;
            tChart1.Header.Text = "";
            pie.Circled = true;
            tChart1.Chart.Panel.Color = System.Drawing.Color.White;
            tChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
            tChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
            Random rnd = new Random();
            int ethnicperc1, ethnicperc2, ethnicperc3, ethnicperc4, ethnicperc5, ethnicperc6;
            ethnicperc1 = 74;
            ethnicperc2 = 4;
            ethnicperc3 = 6;
            ethnicperc4 = 2;
            ethnicperc5 = 5;
            ethnicperc6 = 8;
            pie.Marks.Style = MarksStyles.LabelPercent;
            pie.CustomXRadius = 120;
            pie.CustomYRadius = 120;
            pie.Add(ethnicperc1, "White", Color.FromArgb(49, 151, 101));
            pie.Add(ethnicperc2, "Mixed", Color.FromArgb(255, 255, 255));
            pie.Add(ethnicperc3, "Asian", Color.FromArgb(245, 152, 31));
            pie.Add(ethnicperc4, "Black", Color.FromArgb(205, 205, 205));
            pie.Add(ethnicperc5, "Other", Color.FromArgb(244, 243, 160));
            pie.Add(ethnicperc6, "Not Answered", Color.FromArgb(157, 197, 233));
            pie.Rotate(180);
I recommend you change the angle of rotation to achieve make the pie as clockwise.
For example:
 pie.Rotate(180);
I hope will helps.
Re: Pie Charts
Posted: Thu Oct 27, 2011 12:53 pm
by 8123522
Hi adding the styles has made no difference, my code is:-
Steema.TeeChart.TChart tChart2 = new Steema.TeeChart.TChart();
Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart2.Chart);
tChart2.Legend.Visible = true;
tChart2.Header.Text = "";
tChart2.Chart.Panel.Color = System.Drawing.Color.White;
tChart2.Chart.Panel.Visible = false;
tChart2.Chart.Walls.Visible = false;
tChart2.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Aspect.View3D = false;
pie.Marks.Visible = false;
pie.Marks.Pen.Visible = false;
pie.Marks.Arrow.Visible = false;
pie.Circled = true;
pie.Marks.Style = Steema.TeeChart.Styles.MarksStyles.LabelPercent;
pie.Circled = true;
pie.Rotate(90);
As for the rotatation, I have already tried pie.Rotate(180); this does help I need the green section to start at the top and be clockwise until the other colours appear to left, ie as if the image is flipped
Re: Pie Charts
Posted: Fri Oct 28, 2011 10:29 am
by 10050769
Hello MikeTheLad,
If you want see the difference you achieve changing style of Marks, you need Marks.Visible=true. Please change Marks.Visible=false to Marks.Visible=true and see the results.
Ok. I try change the angle rotation 90 to 270 and I have gotten next image:
Can you tell us if image have the results as you want?
I hope will helps.
Re: Pie Charts
Posted: Fri Oct 28, 2011 10:41 am
by 8123522
The % symbol I require on the legend next the figures, but not on the graph.
I have created in Phtoshop what I require the pie to look like
Re: Pie Charts
Posted: Fri Oct 28, 2011 2:39 pm
by 10050769
Hello MikeTheLad,
Ok. Seems finally I have understood you want achieve. I have made a simple code where used an auxiliary pie series to save the originaly values and other series to manipulate values. Please see next code and check if works as you want:
 Steema.TeeChart.Styles.Pie pie1, pieaux;
          pieaux = new Steema.TeeChart.Styles.Pie();
          pie1 = new Steema.TeeChart.Styles.Pie(tChart2.Chart);
          ethnicperc1 = 94;
          ethnicperc2 = 0;
          ethnicperc3 = 1;
          ethnicperc4 = 1;
          ethnicperc5 = 0;
          ethnicperc6 = 4;
         // Save Originaly values.
          pieaux.Add(ethnicperc1, "White", Color.FromArgb(49, 151, 101));
          pieaux.Add(ethnicperc2, "Mixted", Color.FromArgb(255, 255, 255));//white
          pieaux.Add(ethnicperc3, "Asian", Color.FromArgb(245, 152, 31));//Orange
          pieaux.Add(ethnicperc4, "Black", Color.FromArgb(205, 205, 205));//Grey
          pieaux.Add(ethnicperc5, "Other", Color.FromArgb(244, 243, 160));//Yellow
          pieaux.Add(ethnicperc6, "Not Answered", Color.FromArgb(157, 197, 233));//blue skye
         //Add values
          pie1.Add(pieaux.YValues[5], pieaux.Labels[5], pieaux.Colors[5]);
          pie1.Add(pieaux.YValues[4], pieaux.Labels[4], pieaux.Colors[4]);
          pie1.Add(pieaux.YValues[3], pieaux.Labels[3], pieaux.Colors[3]);
          pie1.Add(pieaux.YValues[2], pieaux.Labels[2], pieaux.Colors[2]);
          pie1.Add(pieaux.YValues[1], pieaux.Labels[1], pieaux.Colors[1]);
          pie1.Add(pieaux.YValues[0], pieaux.Labels[0], pieaux.Colors[0]);
          pie1.Rotate(90);
          tChart2.Legend.Inverted = true;
          pie1.Marks.Visible = false;
          pie1.Marks.Pen.Visible = false;
          pie1.Marks.Arrow.Visible = false;
          pie1.Circled = true;
          pie1.Marks.Style = MarksStyles.LabelPercent;
          pie1.CustomXRadius = 120;
          pie1.CustomYRadius = 120;
          tChart2.Panel.MarginRight = 20;
I hope will helps.
Re: Pie Charts
Posted: Mon Oct 31, 2011 9:29 am
by 8123522
Thank you, that worked, any ideas how I can do the % symbol in the legend, ie
94% white
0% Mixed
1% Asian
etc
If I try to add the % in the following line it fails to build
ie
pie.Add(Convert.ToInt32(ethnicperc1) & "%", "White", Color.FromArgb(49, 151, 101)); This fails
Re: Pie Charts
Posted: Mon Oct 31, 2011 1:09 pm
by 10050769
Hello MikeTheLad,
You only need change TextStyle of Lenged as do in following line of code:
  tChart2.Legend.TextStyle = Steema.TeeChart.LegendTextStyles.LeftPercent;
I hope will helps.
Re: Pie Charts
Posted: Mon Oct 31, 2011 3:48 pm
by 8123522
Thanks, all worked, hopefully that is all
Re: Pie Charts
Posted: Thu May 17, 2018 11:14 am
by 18281487
What is the actual part for triggering that pie data is filled up clockwise instead of default counterclockwise?
Tried playing with RotationAngle without any luck.
Re: Pie Charts
Posted: Thu May 17, 2018 4:02 pm
by 10050769
Hello Bank Van Breda,
I would like suggest you use the Rotate method to change the pie angle rotation and do it works in clockwise direccion. The line code below shows you how can do that:
pie.Rotate(180);
Hoping this helps you,
Thanks in advance
Re: Pie Charts
Posted: Fri May 18, 2018 11:51 am
by 18281487
Like I said, I'm still clearly missing the actual correct code?
So image 1 is regular pie chart, you notice that first value ( dark blue ) is followed by orange rotated counterclockwise.
Screen Shot 2018-05-18 at 13.48.00.png (45.84 KiB) Viewed 41526 times
Second image is same pie with the rotate 180. So now all values are flipped over horizontal axes of the pie, but still fill up counterclockwise...
Screen Shot 2018-05-18 at 13.48.13.png (50.45 KiB) Viewed 41526 times
Any other ideas I can test?
Re: Pie Charts
Posted: Fri May 18, 2018 12:45 pm
by 18281487
Ok found out why this is happening... I added the values to the pie from large to small sorted. Seems the pie chart assumes that data is added in the other sorted direction ( from small to large ).
But because I also show a legend list, I sorted from big to small...
But problem fixed :)
Re: Pie Charts
Posted: Fri May 18, 2018 2:35 pm
by 10050769
I'm glad you can find a solution for your problem. I would like inform you that you can order the PieValues after adding these. You can do that using the Pie Values Order propierty. The line below shows you how can do that:
pie1.PieValues.Order = Steema.TeeChart.Styles.ValueListOrder.Descending;
Thanks in advance
