Demo app failing to start
Captell
Post by Captell » Tue Aug 02, 2011 9:33 pm
Using release 4.1.2011.07280 I'm getting an unhandled exception when I try to start the demo app.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: File or assembly name TeeChart, or one of its dependencies, was not found.
File name: "TeeChart"
at Steema.TeeChart.Samples.MainForm.ShowForm(TreeView tree)
at Steema.TeeChart.Samples.MainForm.treeView1_AfterSelect(Object sender, TreeViewEventArgs e)
at System.Windows.Forms.TreeView.OnAfterSelect(TreeViewEventArgs e)
at System.Windows.Forms.TreeView.TvnSelected(NMTREEVIEW* nmtv)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
=== Pre-bind state information ===
LOG: DisplayName = TeeChart, Version=4.1.2011.7280, Culture=neutral, PublicKeyToken=9c8126276c77bdb7
(Fully-specified)
LOG: Appbase = C:\Program Files\Steema Software\Steema TeeChart for .NET 2011 4.1.2011.07280\Examples\DemoProject\bin\ExecutableDemo\
LOG: Initial PrivatePath = NULL
Calling assembly : TeeChartNetExamples, Version=4.1.2011.7280, Culture=neutral, PublicKeyToken=null.
LOG: Publisher policy file is not found.
LOG: Host configuration file not found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine.config.
LOG: Post-policy reference: TeeChart, Version=4.1.2011.7280, Culture=neutral, PublicKeyToken=9c8126276c77bdb7
LOG: Attempting download of new URL file:///C:/Program Files/Steema Software/Steema TeeChart for .NET 2011 4.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/TeeChart.DLL.
LOG: Attempting download of new URL file:///C:/Program Files/Steema Software/Steema TeeChart for .NET 2011 4.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/TeeChart/TeeChart.DLL.
LOG: Attempting download of new URL file:///C:/Program Files/Steema Software/Steema TeeChart for .NET 2011 4.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/TeeChart.EXE.
LOG: Attempting download of new URL file:///C:/Program Files/Steema Software/Steema TeeChart for .NET 2011 4.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/TeeChart/TeeChart.EXE.
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2470
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
TeeChartNetExamples
Assembly Version: 4.1.2011.7280
Win32 Version: 4.1.2011.7280
CodeBase: file:///C:/Program%20Files/Steema%20Software/Steema%20TeeChart%20for%20.NET%202011%204.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/TeeChartNetExamples.exe
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/Steema%20Software/Steema%20TeeChart%20for%20.NET%202011%204.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///C:/Program%20Files/Steema%20Software/Steema%20TeeChart%20for%20.NET%202011%204.1.2011.07280/Examples/DemoProject/bin/ExecutableDemo/Interop.SHDocVw.DLL
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Adrian Heald
Director
Captell
Re: Demo app failing to start
Post by Captell » Tue Aug 02, 2011 9:34 pm
Sorry, I should have mentioned, I'm running on Windows XP.
Adrian Heald
Director
Post by Sandra » Wed Aug 03, 2011 12:01 pm
Hello Captell,
It is a problem known to us and it is in the bug list report with number(TF02015646). We will be try to fix to next maintenace release. At the moment, you can add the TeeChart.dll in the folder: ...\Examples\DemoProject\bin\ExecutableDemo as a workaround. Please, confirm us if it solve your project.
